Vacum lines 84 kz750 canuck supersport
- 83Zrider
09 Jun 2013 20:27
Im reassembling carbs got them on and find i cant remeber where vac line from tank attaches. Also line to airbox. I have 2 manuals but neither shows where they go. I know the main fuel line goes to center tee on carbs. The outer 2 tubes are vent. A diagram/picyure would or asisstance of any kind would be greatly appreciated. Its almost ready to start.
- kimsmith4807
Re: Vacum lines 84 kz750 canuck supersport
09 Jun 2013 21:54 - 09 Jun 2013 21:56
Do you still have the CAS or emissions stuff still on it? If so, you might have lines coming from carbs #1 and #4 vacuum ports going to a "tee" and then one line that would run up to the CAS. Either #2 or #3 would go to your vacuum activated petcock, the remaining one simply capped off. If you have none of the CAS stuff on the bike, all you need is one line to your petcock. Cap off the rest.
1981 KZ1000-K1 LTD
Last edit: 09 Jun 2013 21:56 by kimsmith4807.
The following user(s) said Thank You: 83Zrider
09 Jun 2013 22:05 - 10 Jun 2013 00:20
Is your bike a 2 or 4 cylinder model? Ed
Last edit: 10 Jun 2013 00:20 by 650ed.
- 83Zrider
10 Jun 2013 20:30
4 clinder "L" or supersport or 82 GPZ it is canada 750 U.S. got 700 because of import tariffs.
- 83Zrider
10 Jun 2013 20:35
What is CAS? As far as emissions unsure if it actually has any? Be europe/canada version not california. It had line going to airbox and of course the crank breather from top motor to bottom airbox. Would that be vacum line?.
10 Jun 2013 23:07U.S. models had Kawasaki's Clean Air System (CAS).83Zrider wrote: What is CAS? As far as emissions unsure if it actually has any? Be europe/canada version not california. It had line going to airbox and of course the crank breather from top motor to bottom airbox. Would that be vacum line?.
CAS included a hose from the air box, and also also drew from vac nipples.
Typical CAS:
Remove CAS:
The following user(s) said Thank You: 83Zrider, kjelderg
- 83Zrider
11 Jun 2013 19:12
Waiting for my boss this am he was late so i got to start hooking up carbs and lines almost there yay!LOL.Ready to add tank then fuel. Thank you guys. Guess should spent money on real kaw manual.
- 83Zrider
17 Jun 2013 21:26
Just fyi fired up after attaching lines and gas, filter for insurance.Had flat though do yet to ride. Thanks to those who offered asisstance
- Graves
04 Sep 2016 05:46
I'm putting my 84 GPz 750 back together after my brother tried to mess with the emission hoses about 20 years ago (the bike's been sitting this whole time in the garage. I'll keep the emission system for now. Can you tell me where the two hose that tee off of the vacuum switch attach? The two hoses marked with the clips 92037? Also, any diagram of how to plumb the fuel separater and cannister? I cant tell where the vent hose from the separater goes. It looks like it goes to a tee ... but I can't find the tee. Tim
- Graves
04 Sep 2016 05:51Attachment ggpz.jpg not found
04 Sep 2016 13:48
Cap the vacuum ports and take that crap off. It doesn't belong on the bike. Better pics of the carbs will help. You'll have fuel inlet, vents and vacuum ports.
