- Thank you received: 6
Dumb Question?!
- badrhino
25 Jan 2013 00:16 #569105
by badrhino
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Replied by badrhino on topic Dumb Question?!
Franken Z!
The following user(s) said Thank You: Motor Head
- Motor Head
- Thank you received: 391
25 Jan 2013 00:17 - 25 Jan 2013 00:19 #569106
by Motor Head
Replied by Motor Head on topic Dumb Question?!
Pretty close to as you described, a set of CV carbs turned 90 degrees. I'd be interested in the inner float bowl working to see how they handle the fuel level and Jetting structure. Seems there would have to be a 90 degree flow of fuel as the fuel in the bowl will be straight level, main jet etc would still have to be low in the fuel level.
Just saw your picture post. You can see the wells that carry the fuel up, main jet is low down in the fuel. I believe the picture is upside down, or downside up.
Last edit: 25 Jan 2013 00:19 by Motor Head.
- badrhino
25 Jan 2013 00:23 #569110
by badrhino
Franken Z!
Yeah I noticed that they have the carbs upside down. Still pretty cool. I bet most people didn't know these were like that.
Franken Z!
- Motor Head
25 Jan 2013 00:37 #569116
by Motor Head
Yea, looks like the Fuel Wells bolt on with 2 screws. I wonder if those are another carb body modified for the fitment on the V Max?
- Rickman
- Thank you received: 1
01 Feb 2013 18:11 #570267
by Rickman
The air runs through my carb (BS34, KZ1100) along a horizontal line. It has an attachment at the left end and at the right end. Therefore the carb is mounted horizontally. Sidedraft carbs are horizontal, downdraft carbs are vertical.
How do you feel about that? Do you have a better reference, preferably something related to the subject field?
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
Replied by Rickman on topic Dumb Question?!
badrhino wrote: I think you better learn what horizontal and vertical mean. Vertical is how the carbs on a KZ or any other inline are mounted. Horizontal is sideways laying flat.
- badrhino
07 Feb 2013 22:04 #571386
by badrhino
Franken Z!
You the man. lmao
Franken Z!
- wireman
- Thank you received: 299
07 Feb 2013 22:11 #571392
by wireman
Replied by wireman on topic Dumb Question?!
Think of it like the float on each end of a holley carb
Attachment holleyfloat.jpg not found
- donthaveakawman
- Visitor
01 Mar 2013 01:58 #574691
by donthaveakawman
Replied by donthaveakawman on topic Dumb Question?!
stay tuned this is not the first and it will not be the last dumb question.
kzrider.com/forum/4-electrical/487392-du...ketecisment-question
