- Thank you received: 299
Petcock problems which one are you using?
- wireman
The adaptor plates are for the 78 style tanks with vacuam petcock ,other tanks use a threaded nipple welded to tank.SeattleKZ wrote:
Powerstroke_fan wrote: you should be able to run a single with a T. but whats wrong with the one you got? if i am not mistaken the pingels are the same they just use diffrent adp plates. So you should be able to get the correct plate and it should work on your petcock.
Z1's customer service told me that the petcock I got won't work with any adaptor plate.
- SeattleKZ
- Thank you received: 3
Not trying to be rude but I already figured out that the Petcock I got is for a 77 tank and based on the Petcock I have my tank must be a 78. My question is what adaptor do you use?
- StreetfighterKz
- Thank you received: 117
Go to www.pingelonline.com/powerflo.htm then click "accessories" and click on "adapter plates". I'd post a direct link but their website is a little goofy.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- gd4now
- Denco where did you go?
- Thank you received: 445
I am still running the original non-vacuum petcock on my 1977 KZ650. It still functions correctly without leaks.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- SeattleKZ
gd4now wrote: The VM 30s that WG is producing and selling are vm26 carbs that have been bored out to just over 29mm. He has indicated he calls them VM30's so that they are not confused with the real vm29's.
Thanks for correcting me, my memory was a little fuzzy on exactly what the carbs were originally. He told me he quit making them until he can find a reliable machine shop and I didn't see them on his site last time I was on there.
- SeattleKZ
StreetfighterKz wrote: Pingel's website shows the adapter plates and lists dimensions between bolt holes. I don't remember which one I used as I bought it 15 years ago but just measure the stock fuel valve and get the adapter with the right spacing. I think I even saw one with the 22mm threads so you can use the fuel valve you have without removing the large nut.
Later, Doug
Perfect, I found the plate that will work thanks.
