Petcock problems which one are you using?
30 Oct 2012 21:59 #556467 by SeattleKZ
I ordered a Pingel petcock and it's not the right one. I guess the tank on my 1977 KZ1000 is from a later year. I want to use a Pingel but now I'm not sure which one to order. I assume that I need to order an adaptor plate and petcock but which ones?
My carbs have to inputs for gas. Can I use a single outlet petcock and put a "T" in the gas line to feed both sides of the carbs?
Here's a picture of the stock petcock I removed and the Pingel that should fit a 1977 KZ.
30 Oct 2012 23:10 - 30 Oct 2012 23:11 #556476 by kwaker
Replied by kwaker on topic Petcock problems which one are you using?
I am using a replacement petcock for a Suzuki GS750 . It is a perfect solution if you don't want to spend an excessive amount of money on a Pingel and adapter plate.
1980 KZ 1000 LTD (daily driver)
1978 KZ1000 (project)
Scottsdale, AZ
Last edit: 30 Oct 2012 23:11 by kwaker.
31 Oct 2012 00:25 #556487 by SeattleKZ
Replied by SeattleKZ on topic Petcock problems which one are you using?
kwaker wrote: I am using a replacement petcock for a Suzuki GS750 . It is a perfect solution if you don't want to spend an excessive amount of money on a Pingel and adapter plate.
Thanks for the suggestion, if I can't get the Pingel thing worked ill give it a try. I'd really like to use the Pingel though.
  • wireman
31 Oct 2012 00:32 #556490 by wireman
Replied by wireman on topic Petcock problems which one are you using?
Depends on what motor/carbs youre running,I used to run an ltd tank on my 1327 till the damn pingle guzzler started sucking it dry too fast and went to a full size z1 tank instead B)
31 Oct 2012 01:17 #556491 by SeattleKZ
Stock 1977 KZ1000 with WGcarbs VM30 carbs.
  • wireman
31 Oct 2012 02:25 #556497 by wireman
vm 30 carbs?
31 Oct 2012 02:42 #556498 by SeattleKZ
wireman wrote: vm 30 carbs?
They're a modified 28 carb set that WGcarbs used to make. They were suggested by Goerge himself but then he couldn't find realiable machine shops so he stopped offering them.
31 Oct 2012 08:34 #556509 by Powerstroke_fan
Replied by Powerstroke_fan on topic Petcock problems which one are you using?
you should be able to run a single with a T. but whats wrong with the one you got? if i am not mistaken the pingels are the same they just use diffrent adp plates. So you should be able to get the correct plate and it should work on your petcock.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
31 Oct 2012 09:22 #556511 by StreetfighterKz
Replied by StreetfighterKz on topic Petcock problems which one are you using?
I use the same Pingel as you have on my '78 1000 with the appropriate adapter plate. You should be able to unscrew the 22mm nut and screw the petcock into the adapter plate. The only thing you need to do is clearance the slot were the stock oval screen fits through to accommodate the round screen.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
31 Oct 2012 09:43 #556512 by SeattleKZ
Powerstroke_fan wrote: you should be able to run a single with a T. but whats wrong with the one you got? if i am not mistaken the pingels are the same they just use diffrent adp plates. So you should be able to get the correct plate and it should work on your petcock.
Z1's customer service told me that the petcock I got won't work with any adaptor plate.
31 Oct 2012 09:45 #556513 by SeattleKZ
StreetfighterKz wrote: I use the same Pingel as you have on my '78 1000 with the appropriate adapter plate. You should be able to unscrew the 22mm nut and screw the petcock into the adapter plate. The only thing you need to do is clearance the slot were the stock oval screen fits through to accommodate the round screen.
Later, Doug
I will measure the threads and check it out. I really hope this works so I don't have to buy another petcock. Thanks.
31 Oct 2012 09:54 #556515 by jbeebe1
Replied by jbeebe1 on topic Petcock problems which one are you using?
just call pingel and they should let you know exactly what you need. They have an adapter plate to fit virtually everything.
79 Honda 400 Hondamatic
79 Honda CB650
81 Honda CX500
81 Honda Passport C70
others coming in and out all the time!
