- Thank you received: 3
Petcock problems which one are you using?
- SeattleKZ
My carbs have to inputs for gas. Can I use a single outlet petcock and put a "T" in the gas line to feed both sides of the carbs?
Here's a picture of the stock petcock I removed and the Pingel that should fit a 1977 KZ.
- kwaker
1980 KZ 1000 LTD (daily driver)
1978 KZ1000 (project)
Scottsdale, AZ
- SeattleKZ
kwaker wrote: I am using a replacement petcock for a Suzuki GS750 . It is a perfect solution if you don't want to spend an excessive amount of money on a Pingel and adapter plate.
Thanks for the suggestion, if I can't get the Pingel thing worked ill give it a try. I'd really like to use the Pingel though.
- wireman
- Thank you received: 299
- SeattleKZ
- wireman
- SeattleKZ
wireman wrote: vm 30 carbs?
They're a modified 28 carb set that WGcarbs used to make. They were suggested by Goerge himself but then he couldn't find realiable machine shops so he stopped offering them.
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- StreetfighterKz
- Thank you received: 117
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- SeattleKZ
Powerstroke_fan wrote: you should be able to run a single with a T. but whats wrong with the one you got? if i am not mistaken the pingels are the same they just use diffrent adp plates. So you should be able to get the correct plate and it should work on your petcock.
Z1's customer service told me that the petcock I got won't work with any adaptor plate.
- SeattleKZ
StreetfighterKz wrote: I use the same Pingel as you have on my '78 1000 with the appropriate adapter plate. You should be able to unscrew the 22mm nut and screw the petcock into the adapter plate. The only thing you need to do is clearance the slot were the stock oval screen fits through to accommodate the round screen.
Later, Doug
I will measure the threads and check it out. I really hope this works so I don't have to buy another petcock. Thanks.
- jbeebe1
- Thank you received: 5
79 Honda 400 Hondamatic
79 Honda CB650
81 Honda CX500
81 Honda Passport C70
others coming in and out all the time!
