- Thank you received: 52
Needle and seat OR Float hanging up?
- kzz1king
kzz1king wrote: Yep, tube method, have a stand made so it is level. It leaks off and on the stand. I am just thinking the move to the stand may make the float hang up.Can have the bike straight up and fuel runs out the mouth of the carb. That is a long ways past the bowl parting line. Shutting the petcock only keeps gas from running out when parked. It does not prevent the cylinder from being flooded when going down the road. The problem is intermittent. Thanks for the comments.
Wayne
One other thing, it is only the number 1 carb.
Home built KZ1000 turbo setup
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
If it still leaks it sounds like a cracked carb body. Possibly where the seat mounts in the body.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- kzz1king
Wayne
BlackZ1R wrote: Have you swapped needle/seats from another carb to see if it still leaks? Float swap?
- Motor Head
- Thank you received: 391
With them off on your carb stand, pull the bowl and hold the float up with your fuel bottle/ source connected. You should see the leak, if at the float valve I would Replace it.
- kzz1king
Wayne
- BlackZ1R
Kawasaki
- Motor Head
With the Web Site change, you need to re-register and set up another account at Z1. Easy to do, and all is still very good with the service.kzz1king wrote: Looks like it is the needle/seat. Swapped 1 and 4 and the slow,steady drip moved to 4. Now if I can remember my Z1 login I was thinking it might be the gasket so I but the seat into the hose on the end of my auxiliary tank and it seeped. Polished it up good to no avail. Thanks all.
Wayne
- wireman
- Thank you received: 299
If your gaskets are still good smear a little chapstick on them to keep them from drying out/sticking
- kzz1king
Wayne
wireman wrote: You can swap them out without removing carbs from bike if you dont mind laying on the floor,saves lots of work pulling/reinstalling carbs.
- kzz1king
They don't have a lot of use on them but a lot of age.BlackZ1R wrote: Aww crud, I was thinking he already had new float valves in place.
Wayne
- Motor Head
kzz1king wrote: Gonna try that chapstick trick,thanks. I got them on the bench. I am going to do everything I can to make sure they work brfore going back on. It is a piece of cake though compared to the carbs on my Concourse.
Wayne
Check out what I did on my Concours to pull the Bowls off easily
www.kzrider.com/forum/13-bike-related/48...t=20&start=60#490194
- kzz1king
Wayne
I already did it! Maybe got the idea from you. I know I seen the dual clock/voltage pics before. You belong to the ZG Fanatics forum too?
Wayne
