Needle and seat OR Float hanging up?
16 Sep 2012 19:47 #549120 by kzz1king
Needle and seat OR Float hanging up? was created by kzz1king
I have had an issue with my #1 carb (29's). In the past it has leaked now and then. Usually a tap or too and it would quit. I had the carbs off and gave a good cleaning. They looked pretty good. I polished the seat, they bench tested ok when I checked float levels via the clear tube.. Put it together and worked fine for a bit, couple short rides. Today it started doing it again.
My bike has a shortened kickstand. Maybe to short as it leans quite a bit. Not sure if related. Could my float be hanging up? How does one tell? I thought about switching needle and seat from another carb and see if problem follows. I want to get what info I can so I dont have them off too many times :angry:
Wayne
Home built KZ1000 turbo setup
  • wireman
16 Sep 2012 20:08 #549123 by wireman
Replied by wireman on topic Needle and seat OR Float hanging up?
Yeah i usually just tap on float bowl with a screwdriver also. :laugh:
did you try shaking the float by your ear while it was out to see if it was sunk/gas filled? B)
16 Sep 2012 21:01 - 16 Sep 2012 21:01 #549131 by moneypit
Replied by moneypit on topic Needle and seat OR Float hanging up?
When I bought my 29s, they had 1 float with some pinholes in it. Found that before they were mounted. Fixed with a little solder. If thats the case, wrap the tang that connects the float to the arm with a wet paper towel as to not melt the solder connecting the float to the arm. (dont ask how I know this)
2-76 kz900
St Paul MN
Last edit: 16 Sep 2012 21:01 by moneypit.
16 Sep 2012 21:15 #549135 by kzz1king
Replied by kzz1king on topic Needle and seat OR Float hanging up?
No, but I thought about it :laugh: Felt ok.
Wayne
wireman wrote: Yeah i usually just tap on float bowl with a screwdriver also. :laugh:
16 Sep 2012 21:17 #549138 by kzz1king
Thanks for the heads up!
Wayne
moneypit wrote: When I bought my 29s, they had 1 float with some pinholes in it. Found that before they were mounted. Fixed with a little solder. If thats the case, wrap the tang that connects the float to the arm with a wet paper towel as to not melt the solder connecting the float to the arm. (dont ask how I know this)
18 Sep 2012 12:05 #549437 by kzz1king
Hope to get the carbs on the bench tonight. Any ideas on how I can bench test them? I tested them last time and they worked fine on the bench. Hoping to get it figured out without to many removal/installations :unsure:
Wayne
18 Sep 2012 13:34 #549450 by kaw-a-holic
Replied by kaw-a-holic on topic Needle and seat OR Float hanging up?
Having the same issue with mine. Bought a new needle and seat same issue. Only happens when on the kick stand, and not on the center stand. That to me means my float level is to high. I thought about taking some old intake manifolds and bolting them to a board with the correct spacing so I can mount the cards a the same angle as it sits upright and on the kickstand. That way the clear tube method is mor accurate.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • mark1122
  • Keep twisting it
18 Sep 2012 15:16 #549463 by mark1122
Replied by mark1122 on topic Needle and seat OR Float hanging up?
This is a very comon problem. ma kawi (and othe manufacturers)fixed it with a vacumm actuated auto shut off petcock .
u can fix it by turning the gas off when u stop. :)
also check that the oring around the seat valve is in good order. they can leak around there.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
18 Sep 2012 22:38 - 18 Sep 2012 22:40 #549585 by kzz1king
Shutting the petcock off is not the problem. The gas runs out of the bell of the carb. It has got to be running to rich. And I can get it to stop but then the problem comes back. If it was only leaking out of the bowl gasket while on side stand for a bit I could deal with that.
Wayne
Mine has the fiber gasket for the seat. That is a good point as a leak there would bypass the needle.
Last edit: 18 Sep 2012 22:40 by kzz1king.
18 Sep 2012 22:44 #549588 by kzz1king
kaw-a-holic wrote: Having the same issue with mine. Bought a new needle and seat same issue. Only happens when on the kick stand, and not on the center stand. That to me means my float level is to high. I thought about taking some old intake manifolds and bolting them to a board with the correct spacing so I can mount the cards a the same angle as it sits upright and on the kickstand. That way the clear tube method is mor accurate.
Mine might be similar,have not pinned it down. Makes me think the float can hang up ometimes when on the side stand. Where and how bad does yours leak? Mine runs out pretty fast.
Wayne
  • BlackZ1R
  • Kawasaki in my blood
18 Sep 2012 23:08 #549592 by BlackZ1R
Replied by BlackZ1R on topic Needle and seat OR Float hanging up?
Never had that problem. But I turn my petcock off on the ride into my driveway.
If you feel the float is sticking when it is leaned over on the stand I would suspect a bad or bent float. Try setting your fuel levels on the minimum side and see if that helps.
How are you checking the level? Bowl drain screw w/clear tube method? Carbs need to be perfectly level.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
19 Sep 2012 00:13 #549608 by kzz1king
Yep, tube method, have a stand made so it is level. It leaks off and on the stand. I am just thinking the move to the stand may make the float hang up.Can have the bike straight up and fuel runs out the mouth of the carb. That is a long ways past the bowl parting line. Shutting the petcock only keeps gas from running out when parked. It does not prevent the cylinder from being flooded when going down the road. The problem is intermittent. Thanks for the comments.
Wayne
