- Thank you received: 664
Regular, Mid-grade, or Premium fuel?
- daveo
With stock engine (pistons, cams, carburetor), is the best choice to use Regular gas? If not, what advantage has another grade over it?
My engine spec compression is 8.9 to 1, whatever that means. Whatever does that mean, anyway?
1982 KZ1100-A2
- Thank you received: 2070
- daveo
1982 KZ1100-A2
- bountyhunter
- Thank you received: 337
It won't hurt anything to run premium. My bike never ran right on 87 octane, I think 89 is OK, but higher than that isn't necessary.daveo wrote: Is it a waste of fuel (and money, of course), if not needed for good combustion? And, if the compression ratio doesn't warrant using Premium, doesn't some unburned fuel blow out the exhaust, and carbon-up the spark plugs?
- Mcdroid
- Gone Kwackers
- Thank you received: 319
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Thank you received: 2829
daveo wrote: Not sure the best category for this question, but here goe's anyway... :whistle:
8.9:1 compression - Is this a Harley or an old Kaw that needs a ring job? :laugh: My KZ650-C1 is 9.5:1. Ed
- daveo
1982 KZ1100-A2
- 4TheKZ1000
- Visitor
To each their own.
- bluej58
- Thank you received: 511
- Kraz1
- gsnfl
77 KZ650 C1 basket case project-blowed up and parted out
83 KZ550 M1-Prince to Toecutter transition
