1984 GPz750 Running Issue
- steell
- rogerdotcom
I am at a loss and want to ride as the weeks pass this is growing extremely frustrating. Do I have to have an air-filter to idle, it seems that the idle circuits would run fine enough with out a box? If anyone can offer any more insights, as it is driving me insane, it would thoroughly be appreciated.
- gengomerpyle
- Thank you received: 17
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- Thank you received: 2098
rogerdotcom wrote: Well, the struggle continues, cleaned the carbs again and installed. Idles on choke and now allows me to drop into the second choke position for a while before dying, it even idles for about five seconds before dying with the choke pushed all the way in.
Thinking pilot circuit issue.
Would check fitment of the plugs and o'rings at bottoms of pilot jets.
- mtkawboy
- Thank you received: 16
- rogerdotcom
Or maybe a pilot screw spring and a passage plug. :blink:
- rogerdotcom
Since I was going to LA this weekend I thought I would bring them by Garage Company. If you haven't been, they are located in Inglewood and to say it is like a museum to classic and vintage motorcycles. They have always been really nice. Tommy and owner Yoshi took a look at them for an hour and a half and couldn't find anything wrong with them. Yoshi said that at this point he would just get new carbs and test them on the bike. What do you guys think?
www.garagecompany.com/
I attached the bike Kiyo built for Born Free and if you haven't seen their 71' CB custom you should.
The small passage between main and pilot might be clogged and thereby preventing sufficient fuel mixture to the pilot outlets.
The pilot plugs are also required.
www.kzrider.com/forum/3-carburetor/510980-pilot-jet-plug
EDIT: Diagram notes that later style BS34 eliminated the small passage between main and pilot.
Too low fuel levels could cause the reported problem.
- H-60MGuy
- 1985 GPz 750 Streetfighter
Ensure that the AIR side of the pilot circuit is clean, etc etc.......BUT......lets say you are running POD filters as I did before my top-up rebuild.
Are they K&N's?
If not, you have the non-K&N pods as I had, and they not only restrict AIRFLOW, but they altogether alter the function of the airbleeds/ports on the front of the carbs, thus the inability to idle unless you are dumping raw fuel into the cylinders, which will show on your spark plugs.
Can you post a pic of your plugs? Also, what are your mixture screws set on? Stock setting WILL NOT work on non-K&N pod filters unless you play with jetting/needle settings.
Pods are awesome for smoothbores or equivalent, but for all-around functionality you really should use factory jetting with factory airbox on BS34's (CV Carbs).
Good luck, will be looking for your reply!
"See, what had happened was.........."
- rogerdotcom
I checked the floats twice but I am willing to do it again, and I may, because I feel a little crazy at this point. Honestly, this has been one of the most frustrating mechanical issues I have dealt with. Yoshi and Tommy made me feel a little better when they couldn't figure it out.
As expected the plugs are filthy from the rich choke setting.
I could not get the stock box so I have tried idling it sans pods and with brand new Uni pods.
I have an old Vance and Hines 4 into 1.
The air bleed has been set closed to 2.5 turns with no luck.
The jetting and needles have been set to Z1's specifications of +1 on the pilots and +3 sizes on the mains, with the needle set on the lowest clip.
Thanks again, I appreciate it.
