- Thank you received: 1
1980 Z1 Carb conversion help needed.
- meckface
As for the intake manifolds I bought mine brand new from Z1 Enterprises which was the cheapest I found them new. I would not buy used since I think I only paid 60 or 70 for a brand new set. Used they could be cracked etc. and not seal good and then you will be just wasting time and money.
I had to use files to bring the mounting holes in closer on the new manifolds to make them fit on my Z1.
As for wiring mine was literally separate. I haven't disconnected any of the EFI wiring it's all tied up and out of the way. Bike runs good and strong. Still need to sync the carbs but I re-jetted them and it seems to have good power and pull through the RPM's now.
The only issue I have run into with mine is that gas will pour out of the overflow on a few of the bowls randomly. Sometimes while the bike is running and sometimes while it's sitting. If I turn the petcock off none will come out. We had adjusted the floats but it could be that they are not correct. Most of the information I could find about adjusting float height had people using a special tool. Very few had the measurements.
- roy-b-boy-b
- Thank you received: 103
- meckface
I'm thinking maybe some crud got in there also. Hopefully that is all that is causing the problem.
- roy-b-boy-b
- meckface
- Roca
- Thank you received: 2
Old Man Rock wrote: Possibly help in getting you going...
NOTE: Keep in mind elevations/temperatures/climate conditions such as humidity etc...
[attacithment=47163]KawiOEMCarbJetsfro26to28mm.jpg[/attachment]
Is this a good rule of thumbs on a 550 too?
1980 KZ550-C2 LTD Custom
- roy-b-boy-b
- meckface
I thought about keeping the stuff but don't plan to ever sell the bike so I really will have no use for any of it.
- Wager
Thanks
Bob
- roy-b-boy-b
Welcome to the forum. Roy
