- Thank you received: 36
1980 kz1000 LTD accelerator pump carb question
- mtbspeedfreak
06 Oct 2011 14:57 #481718
by mtbspeedfreak
Also, if the original bottoms were still on the original VM28s, if they had the 17mm nut on the bottom, they were early 1973 Z1 carbs.
2000 ZRX 1100
1976 KZ 900- Daily Driver
Replied by mtbspeedfreak on topic 1980 kz1000 LTD accelerator pump carb question
wireman wrote:
the old style 28s 73-75 had 2 screws on top ,tops were a lot flatter also.purple_haze wrote: mine are on an 80 ltd, they have the three screws on top and no 17mm pilot jet access nut on bottom, i assumed they were 26s but if they are 28s that would make me happy, i had read the 28s had 2 screws on top and the 17mm nut on bottom, can anyone confirm these are 26s or 28s? i can post a pic if neccesary, but they are the same as the ones in the fleabay link
the bottems interchange between many carbs,tops also interchange on many of the 76-80 carbs
2000 ZRX 1100
- Chaotic Reason
- Thank you received: 15
06 Oct 2011 17:30 #481740
by Chaotic Reason
Michael
1980 KZ1000 shaft drive
Replied by Chaotic Reason on topic 1980 kz1000 LTD accelerator pump carb question
My 80 ST has an accl pump. WHEN my bike was in 1 piece, it would flat get up and move without any problems. It needed to be tuned pretty bad though because it would pop out the exhaust when I let off the gas. But I'm attributing that to a bike that had been sitting for a couple of years and was put together terribly just so I would buy it. I can't wait to see what it'll do when I can finally get it put back together.
Michael
