1980 kz1000 LTD accelerator pump carb question
- purple_haze
05 Oct 2011 01:53
i have an 80 LTD1000, it has the carbs with the accelerator pump built in, why did kawasaki do this?are they interchangeable with non acc pump carbs?
has anybody put a set of 26s with acc pump vs 26s w/o on a dyno and compared? i saw a similar set on ebay that look like crap and they are approaching $200, why? can one of you wise men enlighten me please?
heres the ebay link
cgi.ebay.com/ebaymotors/1980-Kawasaki-KZ...&hash=item35b58e5b6a
heres the ebay link
the trouble with you is the trouble with me, you got two good eyes but still dont see...
jerry
jerry
- mtbspeedfreak
Re: 1980 kz1000 LTD accelerator pump carb question
05 Oct 2011 02:19
I'm curious too. I have an internally stock KZ900 that I use daily- I need needles and needle jets for it to run perfectly on my VM26s. I'm toying with the idea of finding a set of the Z1 VM28s, but the accelerator pump crossed my mind- would such a set up be good for daily use?
2000 ZRX 1100
1976 KZ 900- Daily Driver
Last edit: 15 Feb 2013 11:50 by martin_csr.
- wireman
05 Oct 2011 15:05
the only pumper carbs i remember seeing are the 79-80 28s,it was to compensate the emissions/jetting.
the 28 pumpers are actually decent carbs
- mtbspeedfreak
05 Oct 2011 16:28
I've heard they were decent carbs too- which is why I'm considering them. I'd like to get a set of 28s, like the Z1s had and remember seeing a set of 28 pumpers, which, theoretically, should make the bike a little more livable in daily use.
2000 ZRX 1100
- wireman
05 Oct 2011 17:20
the older style 28s used on 73-75 never had accelerator pumps
- mtbspeedfreak
05 Oct 2011 17:31wireman wrote: the older style 28s used on 73-75 never had accelerator pumps
Correct- didn't the 28 pumpers only come on the '78 Z1Rs?
2000 ZRX 1100
- purple_haze
05 Oct 2011 18:22
mine are on an 80 ltd, they have the three screws on top and no 17mm pilot jet access nut on bottom, i assumed they were 26s but if they are 28s that would make me happy, i had read the 28s had 2 screws on top and the 17mm nut on bottom, can anyone confirm these are 26s or 28s? i can post a pic if neccesary, but they are the same as the ones in the fleabay link
jerry
jerry
- hal0tw0
05 Oct 2011 22:43
My 76 frankenbike came with vm28 pumpers. After last winters rejetting, the bike ran like crap. For the life of me I could not get the bike to idle down at all. I mush have taken the damn things off over 2 dozen times to check/clean/ajust this and that. Somehow the pilots become blocked. I got a set of correct 76 carbs that had been rebuilt and stock jetted just to see how the bike would run. I got the bike running with the pumper carbs real good so the other carbs are just sitting. Im tempted to do some sort of back to back testing on them to see the difference myself
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
- wireman
06 Oct 2011 01:20the old style 28s 73-75 had 2 screws on top ,tops were a lot flatter also.purple_haze wrote: mine are on an 80 ltd, they have the three screws on top and no 17mm pilot jet access nut on bottom, i assumed they were 26s but if they are 28s that would make me happy, i had read the 28s had 2 screws on top and the 17mm nut on bottom, can anyone confirm these are 26s or 28s? i can post a pic if neccesary, but they are the same as the ones in the fleabay link
the bottems interchange between many carbs,tops also interchange on many of the 76-80 carbs
06 Oct 2011 13:33
28mm pumpers are not a z1r only deal tho.
ltd's also had them.
i think most 79/80's got em.
- purple_haze
06 Oct 2011 14:38
nice, thanks for the info, i guess i will be running them, i cleaned them and replaced the pump parts and the bike runs ok, but it kinda hisses and pops and when i whack the throttle she falls on her face, i didnt mess with the air/fuel, maybe i should have? oh yeah, i removed the airbox and was running them bare, any input? thanks guys
jerry
jerry
