1980 kz1000 LTD accelerator pump carb question
05 Oct 2011 01:53 #481431 by purple_haze
i have an 80 LTD1000, it has the carbs with the accelerator pump built in, why did kawasaki do this?are they interchangeable with non acc pump carbs?
has anybody put a set of 26s with acc pump vs 26s w/o on a dyno and compared? i saw a similar set on ebay that look like crap and they are approaching $200, why? can one of you wise men enlighten me please?
heres the ebay link
cgi.ebay.com/ebaymotors/1980-Kawasaki-KZ...&hash=item35b58e5b6a
the trouble with you is the trouble with me, you got two good eyes but still dont see...
jerry
05 Oct 2011 02:19 #481435 by mtbspeedfreak
Replied by mtbspeedfreak on topic 1980 kz1000 LTD accelerator pump carb question
I'm curious too. I have an internally stock KZ900 that I use daily- I need needles and needle jets for it to run perfectly on my VM26s. I'm toying with the idea of finding a set of the Z1 VM28s, but the accelerator pump crossed my mind- would such a set up be good for daily use?
2000 ZRX 1100
1976 KZ 900- Daily Driver
05 Oct 2011 08:30 - 15 Feb 2013 11:50 #481463 by martin_csr
Replied by martin_csr on topic -
Last edit: 15 Feb 2013 11:50 by martin_csr.
  • wireman
05 Oct 2011 15:05 #481516 by wireman
the only pumper carbs i remember seeing are the 79-80 28s,it was to compensate the emissions/jetting.
the 28 pumpers are actually decent carbs B)
05 Oct 2011 16:28 #481532 by mtbspeedfreak
I've heard they were decent carbs too- which is why I'm considering them. I'd like to get a set of 28s, like the Z1s had and remember seeing a set of 28 pumpers, which, theoretically, should make the bike a little more livable in daily use.
2000 ZRX 1100
  • wireman
05 Oct 2011 17:20 #481537 by wireman
the older style 28s used on 73-75 never had accelerator pumps B)
05 Oct 2011 17:31 #481540 by mtbspeedfreak
wireman wrote: the older style 28s used on 73-75 never had accelerator pumps B)
Correct- didn't the 28 pumpers only come on the '78 Z1Rs?
2000 ZRX 1100
05 Oct 2011 18:22 #481555 by purple_haze
Replied by purple_haze on topic 1980 kz1000 LTD accelerator pump carb question
mine are on an 80 ltd, they have the three screws on top and no 17mm pilot jet access nut on bottom, i assumed they were 26s but if they are 28s that would make me happy, i had read the 28s had 2 screws on top and the 17mm nut on bottom, can anyone confirm these are 26s or 28s? i can post a pic if neccesary, but they are the same as the ones in the fleabay link
jerry
05 Oct 2011 22:43 #481595 by hal0tw0
My 76 frankenbike came with vm28 pumpers. After last winters rejetting, the bike ran like crap. For the life of me I could not get the bike to idle down at all. I mush have taken the damn things off over 2 dozen times to check/clean/ajust this and that. Somehow the pilots become blocked. I got a set of correct 76 carbs that had been rebuilt and stock jetted just to see how the bike would run. I got the bike running with the pumper carbs real good so the other carbs are just sitting. Im tempted to do some sort of back to back testing on them to see the difference myself
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
  • wireman
06 Oct 2011 01:20 #481627 by wireman
purple_haze wrote: mine are on an 80 ltd, they have the three screws on top and no 17mm pilot jet access nut on bottom, i assumed they were 26s but if they are 28s that would make me happy, i had read the 28s had 2 screws on top and the 17mm nut on bottom, can anyone confirm these are 26s or 28s? i can post a pic if neccesary, but they are the same as the ones in the fleabay link
the old style 28s 73-75 had 2 screws on top ,tops were a lot flatter also.
the bottems interchange between many carbs,tops also interchange on many of the 76-80 carbs B)
06 Oct 2011 13:33 #481704 by 531blackbanshee
Replied by 531blackbanshee on topic 1980 kz1000 LTD accelerator pump carb question
28mm pumpers are not a z1r only deal tho.
ltd's also had them.
i think most 79/80's got em.
06 Oct 2011 14:38 #481714 by purple_haze
nice, thanks for the info, i guess i will be running them, i cleaned them and replaced the pump parts and the bike runs ok, but it kinda hisses and pops and when i whack the throttle she falls on her face, i didnt mess with the air/fuel, maybe i should have? oh yeah, i removed the airbox and was running them bare, any input? thanks guys
jerry
