- Thank you received: 2
For Ian
- bearshawk
01 Sep 2011 22:13 #473637
by bearshawk
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and...
Replied by bearshawk on topic For Ian
i just looked... NONE of the carbs have that air jet! could there be a reason for this?
the guy i got the parts bike from (found out later it had smoothbores on it) said he bought it from a dealer...perhaps they did something with them.. either way Z1 will be getting some money from me soon
- testarossa
- Thank you received: 82
01 Sep 2011 22:21 #473642
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic For Ian
Did it run like that?
2004 ZX-10R
Angola, IN
- bearshawk
01 Sep 2011 23:15 #473672
by bearshawk
never had them on the bike! the guy hit a fire hydrant going home from the dealer (or so he said) and bent the timing advancer so the bike wouldnt run...bike sat for 2 years and i picked up a complete 79 sr for $150 bucks that came with smoothbores and aftermarket coils, and tapered steering head bearings, so i coulnt really tell you but the guy said it came from a dealership, the key still had the dealers tag when i got it from him. but what else is odd is that its a 650! no work done to it...and they put on smoothies? i dont know much about jetting but i think they are 115 mains if i remember correctly and from what i have read 105 mains should work for the 650...
- testarossa
01 Sep 2011 23:41 #473682
by testarossa
2004 ZX-10R
Angola, IN
The fact that you got a bike with a set of smoothbores for $150 tells me that they didn't know what they had. It probably never ran like that. I don't know what would happen if you tried running it with no air jets but I'm telling you that there is a major restriction missing in that circuit if the jet isn't there. It can't possibly be good.
2004 ZX-10R
Angola, IN
- bearshawk
02 Sep 2011 00:06 #473686
by bearshawk
ha definetly will replace those prior to doing ANYTHING with the carbs,
what i have in them are 115 mains
0-2 needle jets
17.5 pilots
needle clip is on the second to last clip...
0-2 needle jets
17.5 pilots
- Thank you received: 2098
02 Sep 2011 04:01 #473712
by Patton
Replied by Patton on topic For Ian
Following info from Z1E:
29mm smoothbores KZ650
Main Jet 105
Air Jet 0.9
Needle Jet O-4
Jet Needle 5DL31-3
Throttle valve (slide) 1.5mm cutaway
Pilot Jet 15
Air Screw setting 1 1/2 turns out
Main Jet 105
Air Jet 0.9
Needle Jet O-4
Jet Needle 5DL31-3
Pilot Jet 15
- bearshawk
07 Sep 2011 21:05 #474966
by bearshawk
Got the carb back in the mail today, havent taken it apart to look at the labor yet but its back!
Thanks josh
Thanks josh
