For Ian
  • testarossa
  • Topic Author
30 Aug 2011 18:33 #472983 by testarossa
For Ian was created by testarossa
Ian, here you go bud. I'm halfway home on fixing your jet block. My those threads sure were knackered. I guess they made the jet blocks out of chewing gum. Yet another one that the aluminum looked like swiss cheese.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
30 Aug 2011 18:45 #472986 by bearshawk
Replied by bearshawk on topic For Ian
testarossa wrote: Ian, here you go bud. I'm halfway home on fixing your jet block. My those threads sure were knackered. I guess they made the jet blocks out of chewing gum. Yet another one that the aluminum looked like swiss cheese.
WOOOO you rock josh! thanks a million, ill just have to be extra careful with the other 3 :)
a question you may know, are the jets the same for the smoothbores as they are for the vm26's? i was working with my vm26's on the bike and its running OK but i will need some larger mains...it sputters up top
thanks again!
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and...
  • testarossa
  • Topic Author
30 Aug 2011 19:11 #472990 by testarossa
Replied by testarossa on topic For Ian
Main jets are the same, but the pilot jets are totally different. Definantly be careful with the others. It doesn't take much to strip them out. If you find yourself with a 10" Crescent wrench in hand when installing the needle jets, you need to look yourself in the mirror. Thirty lashes with a wet noodle. :) Every one I have repaired so far as looked exactly the same when I drilled into it.
2004 ZX-10R
Angola, IN
30 Aug 2011 21:25 #473018 by bearshawk
testarossa wrote: Main jets are the same, but the pilot jets are totally different. Definantly be careful with the others. It doesn't take much to strip them out. If you find yourself with a 10" Crescent wrench in hand when installing the needle jets, you need to look yourself in the mirror. Thirty lashes with a wet noodle. :) Every one I have repaired so far as looked exactly the same when I drilled into it.
soo all your saying is hand tight is good enough ;)
  • testarossa
  • Topic Author
30 Aug 2011 22:23 #473036 by testarossa
Hand tight plus five degrees. Just one little bump with a very short wrench to snug it. No more than that. Make sure that your threads are very clean before you assemble them. It doesn't take much to jamb up an M6x0.75.
2004 ZX-10R
Angola, IN
  • testarossa
  • Topic Author
31 Aug 2011 19:06 #473336 by testarossa
Good news Ian. The patient made it through surgery just fine. I finished installing the new threaded insert after work today. Everything that I have fits together just fine. You will have to check for interference between the slide and the jet block. It is possible to get the jet block slightly cocked, and this would cause it to rub on the slide. If this happens just get in contact with me, and I can walk you through the adjustment. Unfortunately, without the slide, I am unable to check for interference. One other thing I did notice was that there was no air jet in the air filter side of the carburetor. I don't know if you removed it or is it missing? In any case, I marked the port with the missing jet in the last photo. Good luck with your carbs. I should be able to get it in the mail by tomorrow.
Tapping new threads on the lathe:
Pressing the insert in place:
2004 ZX-10R
Angola, IN
01 Sep 2011 11:37 #473492 by bearshawk
wow thanks for marking that josh, i dont even know if there are jets in ANY of the carbs!! i will have to look into that...
01 Sep 2011 13:47 #473503 by 531blackbanshee
Replied by 531blackbanshee on topic For Ian
top notch work,as always!
is that just a press fit?
or is there some epoxy or adhesive as well?
  • testarossa
  • Topic Author
01 Sep 2011 14:41 #473513 by testarossa
Those are just press fit. I have thought about using some form of loctite or epoxy but I'm not sure about compatibility with current fuels. I have decided to err on the side of not using chemicals. I didn't want Ian to have a gummy mess in there if I had chosen the wrong adhesive. If you don't try and get your jet needle gorilla tight, then the press fit works just fine. I did my own carbs this way, and they are holding up good with about 2000 miles since the repair.
2004 ZX-10R
Angola, IN
01 Sep 2011 16:30 #473544 by 531blackbanshee
sounds perfectly feasible to me.
i just couldn't remember.
thanks for the clarification.
01 Sep 2011 21:44 #473633 by Patton
Replied by Patton on topic For Ian
testarossa wrote:
www.z1enterprises.com/Air-Jet-BS3097-09-...Smoothbore-2659.aspx
Excellent work on the jet blocks. :cheer:
Good Fortune! :)
01 Sep 2011 22:09 #473636 by bearshawk
your the best patton! thanks a ton
