- Thank you received: 82
For Ian
- testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- bearshawk
- Thank you received: 2
testarossa wrote: Ian, here you go bud. I'm halfway home on fixing your jet block. My those threads sure were knackered. I guess they made the jet blocks out of chewing gum. Yet another one that the aluminum looked like swiss cheese.
WOOOO you rock josh! thanks a million, ill just have to be extra careful with the other 3
a question you may know, are the jets the same for the smoothbores as they are for the vm26's? i was working with my vm26's on the bike and its running OK but i will need some larger mains...it sputters up top
thanks again!
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and...
- testarossa
2004 ZX-10R
Angola, IN
- bearshawk
testarossa wrote: Main jets are the same, but the pilot jets are totally different. Definantly be careful with the others. It doesn't take much to strip them out. If you find yourself with a 10" Crescent wrench in hand when installing the needle jets, you need to look yourself in the mirror. Thirty lashes with a wet noodle. Every one I have repaired so far as looked exactly the same when I drilled into it.
soo all your saying is hand tight is good enough
- testarossa
2004 ZX-10R
Angola, IN
- testarossa
Tapping new threads on the lathe:
Pressing the insert in place:
2004 ZX-10R
Angola, IN
- bearshawk
- Thank you received: 797
is that just a press fit?
or is there some epoxy or adhesive as well?
- testarossa
2004 ZX-10R
Angola, IN
i just couldn't remember.
thanks for the clarification.
- Thank you received: 2098
testarossa wrote:
www.z1enterprises.com/Air-Jet-BS3097-09-...Smoothbore-2659.aspx
Excellent work on the jet blocks.
- bearshawk
