Mikunis won't idle down
01 May 2011 19:12 #448095 by Godfrey
Replied by Godfrey on topic Mikunis won't idle down
yes sir, I had that hooked up the day prior to starting this thread, LOL the engine was used in a lawn tractor puller prior to me purchasing it ,so they were only concerned with full power, I'm wondering if the previous owner didn't opt for the smaller jet needle and when reved produces enough vacumn that even with the slides closed its pulling fuel from the needle jet. Guess I'll be pulling them off again and taking the top apart this time.
1981 650CSR frame
1980 KZ750E engine
  • Motor Head
01 May 2011 19:17 #448096 by Motor Head
Replied by Motor Head on topic Mikunis won't idle down
It could have quite a radical cam grind in it. This would play with the Idle as well. Lots of overlap will cause a low vacuum down low, sub 1500. It may fall off both the cam and the ignition causing it to stall. Whats the timing at low RPM, and full advance?
01 May 2011 19:26 #448099 by Godfrey
Motorhead: I expect if I pull the carbs off again I'll be buying the ball bearings to bench sync them;I'm not sure the bowls on these can be equiped attach a manometer to check the float levels but I'll look, the guys who built this motor have raced Kawasakis for yrs, but mostly at the strip. Thanks
1981 650CSR frame
1980 KZ750E engine
  • Motor Head
01 May 2011 19:35 #448101 by Motor Head
A manometer would be for checking the vacuum signal at the carb holders/ intake manifolds. There would be fittings on them, with caps at the moment. Checking the vacuum between cylinders is part of the set up process. Manometer or separate vacuum gauges.
Float bowls have a drain screw, or just a main jet access?
A vacuum gauge with a restriction to even the pulses can be hooked up even to 1 at a time to see differences in cylinders.
What is the compression of your motor, both cranking pressure and the compression ratio if you know.
01 May 2011 20:00 #448109 by Godfrey
Ok I used the wrong term, yes there are caps to remove to change the main jet, but no replacement with fittings for a tube.I have no idea what cranking compression pressure is, its supposed to be a 10:1 engine so not that radical.I just talked to the gent that went thru the engine before I put it in and he said when in the tractor it always idled at 1500 , unfortunately, he had nothing to do with setting up the carburetors, I do understand they were done professionally though.
1981 650CSR frame
1980 KZ750E engine
  • Motor Head
01 May 2011 20:06 #448110 by Motor Head
Well then I'd try to work out the Hot idle first and go from there. 15oo is a decent speed for a motor with upgraded cams.
Try to get the best hot idle possible, giving it throttle to see if it will return. Maybe watch the timing with a light to verify its retuning smoothly.
01 May 2011 21:42 #448142 by Godfrey
Ahh good you are still online, hey motorhead could this problem possibly be from the cam timing being off a link in the timing chain?
1981 650CSR frame
1980 KZ750E engine
  • Motor Head
01 May 2011 22:08 #448157 by Motor Head
that is a possibility, have a check and see. It would cause a low vacuum condition, also check the valve clearance while there.
01 May 2011 22:12 #448159 by Godfrey
all the valves were 3 to 5 thousandths when the guy who assembled the engine went thru it a month ago, but the way those cam chain is tensioned from the valve cover I could see them bein a tooth off
1981 650CSR frame
1980 KZ750E engine
  • Motor Head
01 May 2011 22:17 #448162 by Motor Head
Can you get the specs from the engine builder and degree them? See if it has adjustable cam sprocket, slotted at bolt holes.
  • Becker
  • The Doctor Will Rise Again
01 May 2011 23:46 #448191 by Becker
Replied by Becker on topic Mikunis won't idle down
Try this.
Warm the bike up to full temp and then do the same crack the throttle that caused the idle to hang last time. Then pull the choke. Just for a second. If the idle drops back down and stays there then you just have a lean pilot circuit.
Also, spraying carb cleaner in through the air jet and watching it come out the idle port doesn't mean the jets are clean. You have to pull the pilots and spray them with carb cleaner and run a strand of copper wire through it or other suitable cleaning object.
But I don't think its a plugged jet either. I think the pilot jet is to lean. What size jet is in there??
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
02 May 2011 00:05 #448197 by Godfrey
Hey MH the exhaust sprocket was slotted to get the cam degreed in correctly
1981 650CSR frame
1980 KZ750E engine
