- Thank you received: 10
Mikunis won't idle down
- Godfrey
1981 650CSR frame
1980 KZ750E engine
- Kidkawie
- I bleed premix
- Thank you received: 245
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- dshelly
- Thank you received: 5
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- testarossa
- Thank you received: 82
It doesn't take hardly any fuel at all to maintain 5000rpm when there is no load on the bike, as in sitting in neutral in the driveway. The pilots will totally provide enough fuel with no load.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- Thank you received: 2098
Godfrey wrote: ...KZ750 engine with an 810 kit...Mikuni 34 RS carbs...idle around 1000-1200 rpm , but when I crack the throttle it revs to around 5 grand and stays there. I know the slides have come back down...
Hello, Godfrey, and WELCOME to KZr!
A "racing idle" may also be caused by an air leak, meaning intrusion of outside air into the fuel mixture provided by the carbs.
Often discovered sites for air leaks are old, hard, cracked, worn-out carb holders, and sometimes a loose vacuum plug, or a defective vacuum hose to petcocks.
May test for an air leak by spraying WD40 onto suspected areas while engine is idling, and watching for exhaust smoke or change in rpm.
- kawsakiman
- Thank you received: 6
- turboguzzi
- Thank you received: 72
- Godfrey
1981 650CSR frame
1980 KZ750E engine
- Godfrey
1981 650CSR frame
1980 KZ750E engine
- gengomerpyle
- Thank you received: 17
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- Motor Head
- Thank you received: 391
Then maybe disconnect the throttle cable and try to get the Hot idle sorted out, before going further.
