from four to two
- LLC
- Low Life Cycles
"IF you're doing what you love and doing it well, all the small stuff will come, put your heart into it and you'll still be here when the others are gone!"
- Bluemeanie
- Thank you received: 14
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- TeK9iNe
- What did you do!?!
- Thank you received: 28
You can run the same carbs because you are not drawing to both cylinders at the same time but you will have to use one carb on cylinders 1&4 and the other on cylinders 2&3. Otherwise you will have asymmetrical air flow. The air flow will be 180* out of phase and this will supply more air to one cylinder than to the other if you use one carb on 1&2 and the other on 3&4. This will happen because one cylinder will speed up the air flow for the other but not in reverse. So Yes, to agree with Bluemeanie, jetting will be the least of your problems.
+1 - 2 carbs is not ideal, and makes for serious headaches.
Been there, done that.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- LLC
- Low Life Cycles
I am new to motorcycle engines, but Ive built many hot rods and street rods with all kinds of different intake setups and Ive never encountered anything of the sort.
I appreciate the advice and warnings but If i could get the original question answered, that too would be much appreciated.
Thank you.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
- LLC
- Low Life Cycles
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kzz1p
Hmm Ill try to find something on that. thank you.
You might be able to find some old magazine ads, with that setup in it. I can find, a picture of the carb, at the library....Maybe it's on a CB750 honda.
- LLC
- Low Life Cycles
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- LLC
- Low Life Cycles
I would like to do a single carb off to the side of the engine. But i fear vacuum wont be great enough especially on 1 and 2.
