- Thank you received: 2098
help pls
18 Sep 2010 10:48 #399626
by Patton
Replied by Patton on topic help pls
Capt America wrote:
If this means the bike is being ridden without the airbox hoses in position between the carbs and airbox, with outside air entering directly into carb intake, performance would be expected to suffer.
On the other hand, if speaking only about carb float bowl vent hoses not being connected to air box, would not expect a performance issue from just that.
reaver573 wrote:
...only thing I haven't done is
put on the tubes into the breather box.
So your running cv carbs without the velocity stacks??? If that is the case, get the boots on and the box sealed up properly and your problem should go away.
- gd4now
- Denco where did you go?
- Thank you received: 445
18 Sep 2010 11:27 #399637
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic help pls
Check the spark advancer make sure it moves freely and is lubed. When it is not working correctly you will have issues like the one you are having.
1977 KZ650 B1
