help pls
17 Sep 2010 18:54 #399445 by reaver573
help pls was created by reaver573
I have put the carbs back on my kz750 spectre with the floating height
set at 21mm (per the factory manual specs). It starts and Idles fine, but at around
4500 - 5000k it spits and drops rpms rapidly. Any suggestions??
17 Sep 2010 19:28 #399458 by PLUMMEN
Replied by PLUMMEN on topic help pls
what else has been done to the carbs? B)
17 Sep 2010 19:29 #399460 by Nebr_Rex
Replied by Nebr_Rex on topic help pls
Not enough fuel?
Check tank vent or petcock.
Do you run a filter?
Try these for a start.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
17 Sep 2010 19:37 #399462 by reaver573
Replied by reaver573 on topic help pls
I have put in a set rebuild kits, cleaned everything with carb
cleaner and used Brasso. The only thing I haven't done is
put on the tubes into the breather box.
17 Sep 2010 19:54 #399469 by reaver573
I will check fuel level in bowels next. I am using an
external glass filter.
17 Sep 2010 20:08 - 17 Sep 2010 20:17 #399481 by austin3119
Replied by austin3119 on topic help pls
Try running it without your external filter.
Oh, and run a can of seafoam through your tank. I get lucky a lot of times with this stuff when my carbs are being tempermental. Nice fix for under 10 bucks.
Last edit: 17 Sep 2010 20:17 by austin3119.
18 Sep 2010 07:13 #399567 by reaver573
Ok, without the external filter i can get it up
about 6k rpm and it drops back down. Any
more thoughts??
18 Sep 2010 07:46 #399575 by Nebr_Rex
what bike?carbs?
Is your gas cap clean?
It is your vent.
How about the petcock?
Had a to small of a fuel filter on my first KZ1000.
It would run the bowls dry after sustained high rpm.
Also run a barrel valve (hardware store) instead of a petcock.Requires some welding and fabrication.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
18 Sep 2010 08:21 #399579 by reaver573
Bike is an '82 kz750 spectre with keihin cv34 carbs which I have
rebuilt, cleaned and set the floats to 21mm per factory manual.
I have taken apart the petcock and cleaned it out.
I don't know what else to do, except take it to a shop.
18 Sep 2010 08:34 #399581 by Capt America
Replied by Capt America on topic help pls
So your running cv carbs without the velocity stacks??? If that is the case, get the boots on and the box sealed up properly and your problem should go away.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
18 Sep 2010 10:40 - 18 Sep 2010 10:41 #399623 by Patton
Replied by Patton on topic help pls
reaver573 wrote:
I will check fuel level in bowels next....
Great idea. And should perform clear tube test to determine actual fuel level inside float bowls.
The fuel level is far more critical than float height.
Setting float height to specs may get in the ball park, but often fails to result in correct fuel level.
Good Fortune! :)
Last edit: 18 Sep 2010 10:41 by Patton.
18 Sep 2010 10:44 #399624 by JMKZHI
Replied by JMKZHI on topic help pls
Setting float height to specs may get in the ball park, but often fails to result in correct fuel level...
Yep. For me setting them dry was a complete waste of time.
