help pls
- reaver573
set at 21mm (per the factory manual specs). It starts and Idles fine, but at around
4500 - 5000k it spits and drops rpms rapidly. Any suggestions??
- PLUMMEN
- Thank you received: 104
- Nebr_Rex
- Thank you received: 300
Check tank vent or petcock.
Do you run a filter?
Try these for a start.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- reaver573
cleaner and used Brasso. The only thing I haven't done is
put on the tubes into the breather box.
- reaver573
external glass filter.
- austin3119
- Thank you received: 7
Oh, and run a can of seafoam through your tank. I get lucky a lot of times with this stuff when my carbs are being tempermental. Nice fix for under 10 bucks.
- reaver573
about 6k rpm and it drops back down. Any
more thoughts??
- Nebr_Rex
Is your gas cap clean?
It is your vent.
How about the petcock?
Had a to small of a fuel filter on my first KZ1000.
It would run the bowls dry after sustained high rpm.
Also run a barrel valve (hardware store) instead of a petcock.Requires some welding and fabrication.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- reaver573
rebuilt, cleaned and set the floats to 21mm per factory manual.
I have taken apart the petcock and cleaned it out.
I don't know what else to do, except take it to a shop.
- Capt America
- Born Bad
I have put in a set rebuild kits, cleaned everything with carb
So your running cv carbs without the velocity stacks??? If that is the case, get the boots on and the box sealed up properly and your problem should go away.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
- Thank you received: 2098
I will check fuel level in bowels next....
Great idea. And should perform clear tube test to determine actual fuel level inside float bowls.
The fuel level is far more critical than float height.
Setting float height to specs may get in the ball park, but often fails to result in correct fuel level.
- JMKZHI
- Thank you received: 48
Setting float height to specs may get in the ball park, but often fails to result in correct fuel level...
