carb problems...locked up
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
13 Sep 2010 20:27 - 13 Sep 2010 20:28
#398423
well today before i installed my carbs i tried to manualy move the throttle body and it wouldnt budge. is it something inside frozen? should i take out the bottom end of them and spray with wd, or bolt losner? when i was givin the carbs i was told they need a rebuild whitch i will get to, but for now i just wanna see if the motor runs before i dump any $. thanks
btw its a kz1000 LTD
1978 KZ1000A2
Last edit: 13 Sep 2010 20:28 by kz1k.
  • bikerjim
  • bikerjim's Avatar
  • 1986 T-type Regal
Re: carb problems...locked up
13 Sep 2010 22:15
#398499
I have had the butterfly valves stick a couple times, and also the slides. Both were due to varnish build up, completely seizing the parts. Carburetor cleaner spray directly on the slides and butterfly valves loosened it right up. WD40 also works.
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
  • kz1k
14 Sep 2010 05:22
#398537
thank you...ill give it a shot.
1978 KZ1000A2
  • kz1k
14 Sep 2010 05:36
#398540
well i took the carbs off and sprayed with wd40. letting them sit for a few.......
1978 KZ1000A2
  • kz1k
14 Sep 2010 05:49
#398544
does anyone have a link for a decent deal on a carb rebuild lit for a 79 kz1000 LTD?
1978 KZ1000A2
  • otakar
  • otakar's Avatar
14 Sep 2010 06:02
#398548
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • kz1k
14 Sep 2010 06:17
#398550
thank you....will this work for a 78 too?
1978 KZ1000A2
  • otakar
  • otakar's Avatar
14 Sep 2010 06:25
#398552
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • kz1k
14 Sep 2010 06:27
#398553
cool, i just took the tops and bottoms off my carbs. the floats should move freely right? there are stuck. i sprayed with wd40....not sure how to free these babies up.
1978 KZ1000A2
  • otakar
  • otakar's Avatar
14 Sep 2010 06:33
#398555
Yes the floats should move "very freely" How to loosen them up? Not to be facetious, but very carefully. You brake anything down there, or for that matter bend anything and you are screwed and will be in the market for a new set of carbs. I would say to get a big can of carburetor cleaner and soak the whole lower part of the rack in a shoe box sized "Tupper-Ware" container.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • kz1k
14 Sep 2010 06:39
#398558
carb cleaner ok...i was talking to my dad and he suggested mystery oil...whatcha think?
1978 KZ1000A2
  • otakar
  • otakar's Avatar
14 Sep 2010 06:46
#398560
It might work but I think it's quite a bit more expensive and it will not dissolve everything. If you wish you can add some of it to the "Mystery Oil" to help lubricate after penetration.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
