carb problems...locked up
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
Re: carb problems...locked up
14 Sep 2010 06:49
#398561
well i need to go buy some....i went outside and the floats are moving but 3 are stiff. i sprayed some wd.....but the butterfly valve moves a 1/8th inch and then stops.....
1978 KZ1000A2
  • otakar
  • otakar's Avatar
14 Sep 2010 07:10
#398567
kz1k wrote:
well today before i installed my carbs i tried to manualy move the throttle body and it wouldnt budge. is it something inside frozen? should i take out the bottom end of them and spray with wd, or bolt losner? when i was givin the carbs i was told they need a rebuild whitch i will get to, but for now i just wanna see if the motor runs before i dump any $. thanks
btw its a kz1000 LTD
What year 1000LTD. they changed quite a bit from year to year. Insert your bike particulars into your profile signature and you will no longer have to answer this question. Make sure you include all the bike extras, such as aftermarket ignitions, coils, carburetors and so on.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • otakar
  • otakar's Avatar
14 Sep 2010 07:13
#398570
This is what is confusing, you say "butterfly valve and than you say that it is a 79LTD. They did not have carburetors with "butterfly valves" They had VM26 or VM28 (I forget which) manual slide carburetors. Butterfly carbs were not until the BS34 carbs were introduced on the "J" series motors in 1981.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • muddy1
  • muddy1's Avatar
  • 1980 Kz1000 LTD B4
14 Sep 2010 07:17
#398574
He mentioned 78 as the year a few posts back
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
  • Motor Head
  • Motor Head's Avatar
14 Sep 2010 07:20
#398575
7-77 was the tag on the frame, and down the list there is the carbs, look like VM's not BS's.
  • otakar
  • otakar's Avatar
14 Sep 2010 07:24 - 14 Sep 2010 07:25
#398576
That was what I was presuming, that is why I showed him those rebuild kits. 7/77 should be a 77LTD I believe that the 78s would have started in 9/77. The tag should give him the particular model or we can tell by the VIN. But he keeps on saying "butterfly valves. That is what is throwing me. Maybe someone before him changed the carbs to BS stile.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 14 Sep 2010 07:25 by otakar.
  • kz1k
14 Sep 2010 07:25
#398577
ill take a picture of what i have...brb.
1978 KZ1000A2
  • Motor Head
14 Sep 2010 07:26
#398578
It would help a lot if another picture of the carbs was posted, the one in his other is of a stack of parts with the carbs in view, look like VM's.
  • kz1k
14 Sep 2010 07:30 - 14 Sep 2010 07:34
#398580
yeah the title says its a 78. maybe its wrong? heres some pics with the top and bottom off because im trying to clean them. later i will go get some carb cleaner and let them soak. they have a black almost tar substance on them and in them. the last time it was on the road was 2006. then when i got it last week for free, it was in parts.
the only float that moves freely is the 1 on the right.
1978 KZ1000A2
Last edit: 14 Sep 2010 07:34 by kz1k.
  • kz1k
14 Sep 2010 07:31 - 14 Sep 2010 07:32
#398581
you can see in a few pics the black shiny sticky residue.
the first pic really shows it on the floats.
pay no attention to the bud can...lol
1978 KZ1000A2
Last edit: 14 Sep 2010 07:32 by kz1k.
  • kz1k
14 Sep 2010 07:33
#398584
1978 KZ1000A2
  • otakar
  • otakar's Avatar
14 Sep 2010 07:43 - 14 Sep 2010 07:46
#398589
OK I went back to find out the particulars of this bike.
The frame is a KZ1000-A2 (1978). The front and rear wheels are from a 79 or 80 bike, and the seat is from an LTD. I think that the seat and wheels are what throws us. We should treat this bike as a custom 78 A2 1000. Those carbs look like the stock VM26 carbs with the side adjusting screws like on the 77 bikes the 78 bikes had the bottom adjusting pilot screws. This would mean that the rebuild kit he requires is this one.
www.z1enterprises.com/detail.aspx?ID=43
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 14 Sep 2010 07:46 by otakar.
