carb problems...locked up
- kz1k
- You Cant Fix Stupid!
Re: carb problems...locked up
14 Sep 2010 07:48
so the carbs are 77? ok.....then i need to get a carb kit for that. im glad this forum is here because i dont know what the guy who had this before did. imo he wanted to make it a drag bike and never got around to it.
the floats are freeing up some with time and wd. im sure the carb cleaner will kick it in the butt....i hope. what do i need to know about these carbs? anything special?
1978 KZ1000A2
- otakar
14 Sep 2010 07:58 - 14 Sep 2010 08:01
Since you have a header and I am presuming no air box and you will be using Pod filters you will also require 116 main jets. Use the kit that I posted in my last link/post, and also buy the 115 jets from them. Z1E is the best place to buy parts for our bikes.
www.z1enterprises.com/detail.aspx?ID=57
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 14 Sep 2010 08:01 by otakar.
- kz1k
14 Sep 2010 08:11
OK THANKS OTAKAR!!! so i see the kit....your saying i need to buy additional jets that dont come with the kit? yes there is no air box, and i am running headers.otakar wrote:
1978 KZ1000A2
- otakar
14 Sep 2010 08:14
Yes you will require additional jets. the reason is because the kit only comes with the stock jet sizes. you will have to go about 3 sizes larger to accommodate the lack of the airbox and the VH header you have.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kz1k
14 Sep 2010 08:25
thank youu, you have been very helpful!!!! so were looking at about $100. might be a minute before i can grab the kits and jets. but ill figure it out.
1978 KZ1000A2
- kz1k
14 Sep 2010 10:32
how long should i let them soak in the carb cleaner? then should i blow them out with my air compressor?
1978 KZ1000A2
- TeK9iNe
- What did you do!?!
14 Sep 2010 12:21 - 14 Sep 2010 12:21
kz1k wrote:
Just keep checking them periodically, like every couple hours. They need to be shiney new, and free of all debris.
The compressed air is always a good idea.
Remember to completely dissasemble the portions of the carbs subjected to dunking/carb cleaner sprays, as they destroy rubber/o-rings.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 14 Sep 2010 12:21 by TeK9iNe.
- bikerjim
- 1986 T-type Regal
14 Sep 2010 13:04
Make sure you read that again and heed that advice. Ask me how I know.........
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
