Jet Needles / Main Jets / Gas Mileage
- WABBMW
- Let The Good Times Roll !
23 Jul 2010 20:46
My '82 KZ650 had stock main jets and single groove jet needles. The bike got great gas mileage (52 - 57 MPG), ran smoothly, but seemed to lack power from 1/4 throttle and above.
I used washers to raise the jet needles by 4 mm., and increased the Main jets by two sizes. Now the bike runs really strong, but the gas mileage dropped to about 43 MPG.
From what I read, if I go very easy on the throttle, (never open more than 1/4), then the Main jets should not affect gas mileage. Is this true?
I expect that I may have gone a little too far on raising the jet needles. Does anybody know the spacing between the grooves on adjustable jet needles? How many grooves does the 4 mm. equate to? Please advise. Thanks.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
Re: Jet Needles / Main Jets / Gas Mileage
23 Jul 2010 20:52
If I remember right, the needle slots are 1mm apart. So you've raised them 4 notches. That's quite a jump.
West Linn, OR
- Motor Head
23 Jul 2010 20:57
And that would be more than what would be on a needle with notches. Be careful they don't leave the needle jet bore and stick your slide valve open at WOT!!!!
Sounds like you are masking over another problem, such as vacuum leaks or possibly a low float level, leaking slide diaphragm, or some PO has done some drilling on the air bleeds or changed gets/ needle to something leaner.
23 Jul 2010 21:10
Carb needle shims are shown in the Sudco catalog (Mikuni Tuning Manual 4th Edition):
i.d. .106
o.d. .250
thickness .020 (.5mm)
Seem to remember reading somewhere that 2 shims equals one clip position, which is consistent with Skyman's recollection of 1mm between clip positions.
i.d. .106
o.d. .250
- otakar
23 Jul 2010 21:12
The main jets will not affect your millage at all, unless you ride at wide open throttle all the time the needles will. One to two mm is a big change on a needle. Four mm will definitely kill your millage.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
23 Jul 2010 22:03
WABBMW wrote:
On mine the grooves are about .030" apart. I think that is 0.75mm?I expect that I may have gone a little too far on raising the jet needles. Does anybody know the spacing between the grooves on adjustable jet needles? How many grooves does the 4 mm. equate to? Please advise. Thanks.
- Becker
- The Doctor Will Rise Again
23 Jul 2010 22:35
Is the .75mm reading center to center or just the thickness of material between the slots??
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
23 Jul 2010 22:36
bountyhunter wrote:
NO FAIR measuring!
:laugh: :laugh:
...On mine the grooves are about .030" apart. I think that is 0.75mm?
NO FAIR measuring!
- WABBMW
24 Jul 2010 07:07 - 24 Jul 2010 07:11
I plan on changing the jet needle position again, and from what you provided, I should be able to dial in just right this time. The stock setting seemed quite lean, so I may go the equivalent of one or two grooves richer than stock, instead of the quantum leap that I did.
I'll provide feedback as to how it works out. Thanks everybody.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
Last edit: 24 Jul 2010 07:11 by WABBMW.
- Kawickrice
24 Jul 2010 08:55
I am happy with 35 miles a gallon
I usually ride hard so fuel mileage is out the window
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- otakar
24 Jul 2010 11:25
They should be 1mm (.040") apart center to center.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
24 Jul 2010 13:13 - 24 Jul 2010 13:16
Becker wrote:
Center to center across the slots. I used dig calipers across five slots measuring from the top edge of the upper and lower slot, then divided by four. I think that's the right value, but my eyes are not as young as they used to be. I couldn't bet my life that it's not 1mm.Is the .75mm reading center to center or just the thickness of material between the slots??
Last edit: 24 Jul 2010 13:16 by bountyhunter.
