Jet Needles / Main Jets / Gas Mileage
- otakar
Re: Jet Needles / Main Jets / Gas Mileage
24 Jul 2010 17:58
Each slot is .5mm wide. if the spacing was .75mm each divider would only be .25mm. I have never seen them that thin.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
24 Jul 2010 23:29 - 24 Jul 2010 23:31
Yea, I think 1mm is right. I probably eyeballed it crosseyed.
Last edit: 24 Jul 2010 23:31 by bountyhunter.
- andy9802gt
- If it tastes that good, eat it yourself.
05 Aug 2010 18:29
If you have to move clip positions all the way up or down your needle to get it to run right then you need to obtain the next richer or leaner needle or go up or down one size on the jet that the needle is overlapping at the problem throttle position.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- WABBMW
- Let The Good Times Roll !
09 Aug 2010 19:26
I changed the shims under the jet needles from 4 mm. richer than stock, down to 1mm. richer. The bike was definitely too rich before. It runs much more crisply now, still with good power. I still have the Main jets at 2 sizes richer than stock. Pulls really hard at WOT.
The only thing that puzzles me, is that the gas mileage is still the same, at about 43 MPG, as it was with the 4 mm. shimming. I have made the same run at least 50 times, and can usually predict the mileage within 5 MPG. The way I was riding, it was averaging in the low 50s before with stock Main jets and jet needles in the original single clip position. And I was riding easy - not over 1/4 throttle. I am surprised that 1 mm. hurt the mileage that much. Maybe there is something else going on, but I don't have a clue what it might be. Any ideas out there?
Thanks for all the replies.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- larrycavan
10 Aug 2010 05:40
WABBMW wrote:
If the airbox is still on the bike and the exhaust system is stock, you shouldn't need to go up 2 on the main jets.
You might try leaving the needles where they are and going back down to the main jets you had before.
The thing with fine tuning jetting is you have to try and see what's best.
- 9am53
- homebrew, and some bbq
10 Aug 2010 05:54
Did you change the pilot jet? I thought it was responsible for cruising fuel supply.
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- WABBMW
10 Aug 2010 06:37
The airbox is completely stock, and has been all along. The boots are in good condition and not leaking. The air filter is almost new.
I changed the pilot jets several years ago, from 37.5 to 40.0, and the gas mileage still averaged 53 to 57 MPG afterward.
I modified the exhaust slightly, but this was a couple of years ago. Gas mileage both before and after this modification stayed the same 53 - 57. The motorcycle did seem slightly lean after the MOD. All I did to the stock 4 into 2 system, was to weld in a smooth "Y" fitting between the pipes from cylinders 1 & 2, and also between 3 & 4. The original had an almost right-angle intersection where the pipes meet. Also the pipe exiting the "Y" toward the muffler is about 1 3/4". Mufflers have stock baffeling.
My gas mileage with the BS32 carbs always seemed to be higher than most other KZ650s, and I attributed this to what I thought was very lean jetting when stock. Then with the exhaust work, I decided to go 2 jet sizes richer on the Mains. This may have been a mistake, but I would think that it would not even come into the picture until about 3/4 throttle and above.
I still wonder if the larger Main jets are impacting the mileage and making the overall mixture richer. I have deliberately kept the throttle open no more than 1/4 at any time during this testing.
More comments and opinions are very welcome. Thanks.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- TeK9iNe
- What did you do!?!
10 Aug 2010 06:59
The air/mixture screws can have a generous effect onmileage, have you played with them/richened them up in order to obtain a better idle?
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- 9am53
10 Aug 2010 07:16
Although, now that I think about it, since my most recent rejet where I dropped the needle clip 2 slots and went up in the mains by 2 sizes (similar to you) my fuel economy has kind of suffered, I get around 6.3 litres/100km now where I used to get around 5.something... (20 % worse) but my power is way up...maybe it is the needle after all...i digress, listen to those who know what they are doing
'84 GPz900r
'71 CB350
'71 CB350
- WABBMW
10 Aug 2010 07:18
No, I synched the carbs and set the idle mixture about 5,000 miles ago. It idles so smoothly that if I have ear plugs in, and come to a stop, and there is any noise around such as a truck, I have to look down at the tach to see if it is still running. Haven't touched the mixture screws for a long time.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
10 Aug 2010 07:45
Sorry if already mentioned, but would also check fuel levels in float bowls using the clear tube test method.
An incorrect fuel level will impact otherwise perfect jetting and fuel metering.
- mark1122
- Keep twisting it
15 Aug 2010 14:47
raisng the needles, by lowering the clip(richer), and the pilot jets, screws will affect the cruseing speeds fuel milage. the main jet should have no afect.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
