- Thank you received: 225
VM24 SS Carb Settings (Straight Pipes & Pods)
- Old Man Rock
Blue, Steve, where are ya?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Old Man Rock
The ribbed carb bodies are listed there as well for the KZ650... My KZ650 manual depicts OEM as VM24s...
cgi.ebay.com/ebaymotors/KAWASAKI-KZ650-K...&hash=item58879f7c34
KAWASAKI KZ650 CARB KIT
1977-78
K&L Kit 18-2429
One Kit fixes one carb, bid price is for one kit
Kit include:
includes float gasket; Y63 slide needle and clip, float needle and seat; 97.5, 102.5 , 90 and 102 main jets, #15 slow jet; air screw, spring; misc packing as applicable
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Sircraigery
Can you suggest some settings? I adjust my floats to 22mm (including the gasket) as another member suggested, and they still leak like crazy.
Here are my settings for these carbs:
102.5 main (biggest that came in my rebuild kit)
2nd needle clip
EDIT: - Answered my own question.
I have the carbs sync'd from the slide height. The pilot screw doesn't seem to affect the syncronization, at least the digital meter doesn't change. Does that mean my slides are too high or something?
The spark plugs are finally a tan brown, no longer black and fouled. It's actually running really good now, but it bogs a bit when I go to give it some juice. Once, the revs are a bit higher it's got quite a bit of power.
Sugesstions?
- Sircraigery
- Nebr_Rex
- Thank you received: 300
Sugesstions?
sounds a little lean
try raising the needle and/or larger pilot jet
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Sircraigery
I'm in Saskatchewan, Canada, btw (I remember someone asking me before).
Does anyone know if a vacuum fuel valve will stop the carbs from leaking out? They spilled a full tank of fuel all over the garage....again (after I thought they were fixed).
- Thank you received: 2098
...Does anyone know if a vacuum fuel valve will stop the carbs from leaking out? They spilled a full tank of fuel all over the garage....again (after I thought they were fixed).
Perfectly functioning carbs will maintain correct fuel level in float bowls with engine off and petcock allowing fuel flow.
Fuel escaping from the overflow circuit results from excess fuel getting through the fuel valve for whatever reason. Reasons may include:
--- insufficient seal between float needle and seat orifice (dirt, grit or wear)
--- incorrect float height
--- sticking float
--- improperly installed float
--- damaged float
--- leaking float
--- cracked overflow tube
A properly functioning manual petcock in OFF position or vacuum petcock in ON or RES position, with engine not running, prevents fuel flow to the carbs, thereby serving as a fail-safe to prevent possibility of excess fuel getting through the fuel valve for whatever reason noted above.
But such properly functioning petcock does not "cure" the imperfectly functioning carb.
It's at this point that cleanliness and fit are essential.
And a primary reason to assure fitment of a good accessory aftermarket inline fuel filter. The oem petcock screens are helpful, but are by themselves woefully inadequate for this purpose.
Also remember that float needles and their seats are married for life, and should not be mixed and matched incident to carb work.
Sometimes the float valve in a freshly assembled dry carb might leak when first exposed to incoming fuel, evidenced by fuel from its overflow circuit. This condition may often be remedied while the engine is running by rapping smartly against the float bowl with a plastic mallet or screwdriver handle.
- Old Man Rock
jarlef.no/Kawasaki/Series/Z/650/z650files.htm
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Sircraigery
If no avail, I'll let you guys know.
Ok, I'll try those tips, thanks guys. I'll also get a fuel filter. If no avail, I'll let you guys know.
Unfortunately, many freshly cleaned pristine carbs have been instantly re-contaminated by the first onslaught of incoming fuel which hasn't first passed through a good in-line filter.
Z1E carries the in-line filters, as do most all bike shops and dealerships.
Click > Several styles
I use the KL19-1272.
Click > KL19-1272
- Sircraigery
members.home.nl/verbra/home.htm
GREAT SITE!!
I FINALLY found a number that sounds more feasible for the float levels, 30mm. I had them around there before and they didn't leak.
