'80 KZ750 LTD Leak!!!!! I need help please!!!
- xLowEndx
- Slappa da bass
18 May 2010 12:38 #368782
by xLowEndx
1980 Kawasaki KZ750-H1 LTD
Replied by xLowEndx on topic '80 KZ750 LTD Leak!!!!! I need help please!!!
Thanks, sounds about right.
- JR
- Thank you received: 449
18 May 2010 18:15 #368851
by JR
Replied by JR on topic '80 KZ750 LTD Leak!!!!! I need help please!!!
Yep, thats the idles adjustment screw. It is located just below the fuel T. This is the T junction where the gas enters the carbs between #s 2 nd 3. I would advise that you maybe take the gas tank off and have a look in that area. I dont think it will be a difficult fix
- schmol
26 May 2010 09:22 #371040
by schmol
Replied by schmol on topic '80 KZ750 LTD Leak!!!!! I need help please!!!
Check your petcock, with these older bikes the inards of the petcock dry out and will cause the carbs to leak fuel.
- xLowEndx
- Slappa da bass
26 May 2010 09:34 #371045
by xLowEndx
okay cool. Is it necessary to have a prime option on the bike or can I do away with it all and just get a replacement that has an on, off, and reserve instead?
Sounds easier to me and a definite cut-off from the gas line. No worry about leaks or bad vacuum seals....
- JMKZHI
- Thank you received: 48
26 May 2010 12:13 #371079
by JMKZHI
Replied by JMKZHI on topic '80 KZ750 LTD Leak!!!!! I need help please!!!
You can install a manual fuel valve no problem.
Have you changed the oil yet?
- xLowEndx
- Slappa da bass
26 May 2010 12:33 #371089
by xLowEndx
JMKZHI wrote:
Yep, after riding for about 25 min to a friends house we started to drain the oil and thats when I realized my 1st carb was leaking through the vent into the air box. I lost 2 gallons because of that. Had enough gas to get home and ran it pretty dry.
yay, no leaks.... til I add some more fuel....
This sucks.
This sucks.
