'80 KZ750 LTD Leak!!!!! I need help please!!!
- xLowEndx
- Slappa da bass
This is my first post on this forum and this bike is my first motorcycle ever! I bought this bike and it starts up fine and runs but I do know I will need to change the oil immediately before I ride it anymore.
My biggest concern now is that I have a leak that smells like gasoline but is a little thicker and more oily. It is dripping from a small valve that faces the rear of the bike that comes down right in between the carbs. It's not too bad but I've had the bike for 4 days now and it hasn't stopped.
I'm not sure what this "valve" is but it does turn in place but doesn't seem to close.
Should there be a hose coming from it?
What is this leak?
(this is an inline 4 btw)
(I'm not a complete novice but my motorcycle mechanics consist of being able to point out the basic parts of a bike and understanding ehat they do, just not how they do it)
1980 Kawasaki KZ750-H1 LTD
- H1Vindicator
- Thank you received: 53
- apbling
- Thank you received: 12
- xLowEndx
- Slappa da bass
Um, I looked at the diagrams and I'm not too sure if the "valve" has anything to do with the carbs. The piece I'm talking about is only about the size of a nickel. It has about 12 "grooves" in it that look teeth on a gear. This is was lead me to believe it was meant for turning so it gives you more grip.....
Any other ideas before I can get these pics up?
- coltsfan
- xLowEndx
- Slappa da bass
- Thank you received: 2098
You are correct, it looks like it is coming out just below and in between carbs 2 and 3. I can't get pics up for another 8 hours cuz I'm at work and I think in most forums you may have to have a min. amount of post before you can post a pic.
Hello, Chris, and WELCOME to KZR!
We're glad you're here!
think in most forums you may have to have a min. amount of post before you can post a pic --- No such requirements on KZR forum, so post away.
Would the parts in question be those below enclosed in red?
[Click on image to enhance view.]
- xLowEndx
- Slappa da bass
That is right where it is at though. What is it?
Many FSM's covering 1980 KZ750 are listed on ebay, and inexpensive CD versions are often also available. Sometimes a supplement manual is printed for LTD models. But most LTD info will be covered in manual for standard model.
Meanwhile, I think but am not positive that the part involved is for adjusting the idle speed.
- apbling
I chased lots of leaks on my bike because it sat for a long time. Just when you fix one, another pops up Usually nothing too hard to handle though.
- xLowEndx
- Slappa da bass
Where should it idle @ in rpm's?
- hocbj23
- Visitor
