- Thank you received: 235
No start / Hard start
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Thank you received: 2098
Also try using the kick starter (where available), whereby more battery power is devoted to ignition.
- Tony
- Thank you received: 13
Bike was hard starting last summer. It turned over many many times before it would start. I thought the coils were weak so this year i put two new dyna coils on rewired the coils with the WG mod and a new battery because it turned over so much last year it killed it.
Compression all good,checked ignitor good, lots of spark. the fuel had stabilizer prior to storage. I drained the carb bowls and blew compressed air through the drain holes and fuel line and vacuum line for shit and giggles.
I tried it again and it stumbled and after turning over about five or six times it started and ran fine. I took it for a drive and it ran great!!
I tried it after about ten minutes later and it started on first touch of the starter button. O left it for 4 hours and it is a no go!! I turned the fuel to pri,res still no go. It was hard cold starting since last year.
So we got fuel,we got spark what a missin??
I had this same problem. After some checking the only thing I found wrong was the valve clearances were very tight. I adjusted them and problem solved.
- 2bskor
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
- Tony
- trianglelaguna
carry on..
reading with interst here....
1976 KZ900
2003 ZX12R
2007 FZ1000
- 2bskor
- the wolf is watching
I got the same issue... I took off carbs, cleaned completely... battery is good, I just bump started it, it rode for about 1/8 mile and died, acted like it was running out of gas. I put pod filters on and havnt changed the needle so Im sure that is an issue, but as far as starting... ??? so where is the valve clearances located, I cant find it in my manual... thanks and Ill be checkin to see if your issue was resolved, as I think I got the same prob (kz550a)
- 2bskor
- trianglelaguna
my questions were amswered by tony in a p.m and i kinda understand the petcok positions better.....
do you have 28mm carbs with an accelerator pump...and emmisions tubes on your cam cover???
{tony has a canada model with normal carbs and no valve cover breathers....)
but on a same note as your topic...i charged my MK11 battery all day came home and cranked it with the starter for about tweny turns...dadadadaadadadaadadadaaadadadadaadadaadadadada...nothing...i think my issue is no fuel......
carry on....i wanna know when you get a solution.....
thanks...craig
1976 KZ900
2003 ZX12R
2007 FZ1000
- 2bskor
Bike started even on a cold morning drove it around even 12 kms to work, the carbs are a little rich because I took out the air screws and didn't adjust quite right yet.
I used some Yamaha penetrant as suggested by a friend this stuff makes seafoam look like dollar store perfume!!
BAD NEWS after driving today my new Gel Cell battery is dead. In all honesty I kinda killed it trying to start the bike when it was cranking only. I did charge it but who knows? I got a new one.
Is there a way...I know there is , I should ask how to check your regulator and or stator(generator). I remember last year one of the fuses getting hot and I did go through a battery last year but it was an old acid type.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Connect a voltmeter to the battery.
The voltage should be at 13 - 13.5V while idling.
Rev the bike to past 4Krpm and you should get 14.5 - 15V, but not higher! It shouldn't continue to increase the higher you rev the bike...
If higher, rect/regulator is toast.
If Voltage never rises to 13+ check stator:
Turn off bike.
Unplug the 3 stator wires.
use ohm meter and check to make sure infinate resistance between all 3 wires and ground - NO READING AT ALL. ( 0.0 means bad.)Meter should do nothing...
Start bike.
Set Voltmeter to AC.
Connect to ground and one stator wire at a time.
Revving bike should give you 50+Volts AC on each line, then stator is good. Rect/regulator is toast.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
