- Thank you received: 2
No start / Hard start
- 2bskor
Compression all good,checked ignitor good, lots of spark. the fuel had stabilizer prior to storage. I drained the carb bowls and blew compressed air through the drain holes and fuel line and vacuum line for shit and giggles.
I tried it again and it stumbled and after turning over about five or six times it started and ran fine. I took it for a drive and it ran great!!
I tried it after about ten minutes later and it started on first touch of the starter button. O left it for 4 hours and it is a no go!! I turned the fuel to pri,res still no go. It was hard cold starting since last year.
So we got fuel,we got spark what a missin??
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- 2bskor
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Are you angry at your bike or something?!?!
It really does suck in alot of garbage thats just floating around in the air, and makes it very lean.
Put the air filter in and use full choke to start w/no throttle input.
GL
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- 2bskor
I don't drive without a filter it is now in as it was drying before being oiled. It is in and it doesn't make a difference for my problem .... I only wish it did.
Seafoamed the shit out of the carbs and drained all the old gas out of them and the tank. Trying everything before those carbs come have to come off!!
- Sandy
- Fly High,Tony
- Thank you received: 13
- 2bskor
I really am leaning toward a carb problem. But it kinda baffles me that it wouldn't stumble at all. I would think it would at least stumble if not start for a second and stop:(
Thanks for your suggestion
- Motor Head
- Thank you received: 391
- 2bskor
Thanks
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- 2bskor
Does your petcock have two lines running to it if it does it is vacuumed controlled. The reserve would be with the tab part of the petcock pointed forward the on is pointed down and it would freeflow and if pointed back it would be activated by the vacuum of the motor.
I don't know if this helps but it's my 2 cents!!
Look at your library for a manual mine had one !!
- Thank you received: 2829
curious:
my new (to me) MK11 is not starting by the starter motor turing over....it did start when i was kicking it at the garage sale.....and i finaly ,felt,thought,it was not flowing fresh fuel into the carbs...kinda like sandy said...so i ran down the street and bump started it...got the gas station added fresh high oct...and still no starter button firing up...bumped it rode it home...took it out to fiddle with yesterday and chrged bat...but would only bump start...
Sounds to me like the starter is drawing so much current that there's not enough left to fire the plugs. If it was a fuel or carb problem I wouldn't think you could bump start it. I'd check the ground in the starter circuit and the starter itself to see if it's drawing more current than normal. Ed
