No start / Hard start
21 Mar 2010 17:21 - 21 Mar 2010 17:22 #355278 by 2bskor
No start / Hard start was created by 2bskor
Bike was hard starting last summer. It turned over many many times before it would start. I thought the coils were weak so this year i put two new dyna coils on rewired the coils with the WG mod and a new battery because it turned over so much last year it killed it.
Compression all good,checked ignitor good, lots of spark. the fuel had stabilizer prior to storage. I drained the carb bowls and blew compressed air through the drain holes and fuel line and vacuum line for shit and giggles.
I tried it again and it stumbled and after turning over about five or six times it started and ran fine. I took it for a drive and it ran great!!
I tried it after about ten minutes later and it started on first touch of the starter button. O left it for 4 hours and it is a no go!! I turned the fuel to pri,res still no go. It was hard cold starting since last year.
So we got fuel,we got spark what a missin??
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
Last edit: 21 Mar 2010 17:22 by 2bskor. Reason: wanted to subscribe
21 Mar 2010 17:24 #355281 by timebomb33
Replied by timebomb33 on topic No start / Hard start
hows your air filters. thats the only from your equation that your missing unless it has another problem.
I THINK MY POWERBAND BROKE
21 Mar 2010 17:50 #355298 by 2bskor
Replied by 2bskor on topic No start / Hard start
actually the filter is not in it at the moment as it is drying prior to oiling it k&n i think it would run with or without as it did start up eventually without it today. thanks for your suggestion.
  • TeK9iNe
  • What did you do!?!
22 Mar 2010 16:12 #355487 by TeK9iNe
Replied by TeK9iNe on topic No start / Hard start
Running without filter!
Are you angry at your bike or something?!?!
It really does suck in alot of garbage thats just floating around in the air, and makes it very lean.
Put the air filter in and use full choke to start w/no throttle input.
GL
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
22 Mar 2010 19:14 #355516 by 2bskor
I am a bit angry at the old girl :)
I don't drive without a filter it is now in as it was drying before being oiled. It is in and it doesn't make a difference for my problem .... I only wish it did.
Seafoamed the shit out of the carbs and drained all the old gas out of them and the tank. Trying everything before those carbs come have to come off!!
22 Mar 2010 20:30 #355528 by Sandy
Replied by Sandy on topic No start / Hard start
Vapour-lock at the tank maybe?
1977 KZ1000 A-1
23 Mar 2010 04:10 #355552 by 2bskor
Maybe but it has been an ongoing problem since the end of last riding season. I will see what if anything the seafoam /new gas will do if anything:ohmy:
I really am leaning toward a carb problem. But it kinda baffles me that it wouldn't stumble at all. I would think it would at least stumble if not start for a second and stop:(
Thanks for your suggestion :)
  • Motor Head
23 Mar 2010 05:07 #355565 by Motor Head
Replied by Motor Head on topic No start / Hard start
Well sounds like you have a lean condition. This could be caused by a simple choke cable adjustment, also a vacuum leak at the carb manifolds, then of course the circuits in the carb's could be restricted, low float level will cause a lean condition. If it is only when cold try enriching the mixture yourself with some added fuel to the intake while cranking, if it fires right away you know its lean.
23 Mar 2010 06:22 #355575 by 2bskor
Some good ideas. I might try something in the air intakes. Last year I tried starting fluid and it worked so you may be on to something B) I don't have a choke cable just a lever on the side of the carbs.
Thanks
  • trianglelaguna
23 Mar 2010 06:40 - 23 Mar 2010 11:05 #355580 by trianglelaguna
Replied by trianglelaguna on topic No start / Hard start
curious:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 23 Mar 2010 11:05 by trianglelaguna.
23 Mar 2010 07:21 #355594 by 2bskor
Well I wish mine would bump start but it just turns until the battery gives out. My bike had electronic ignition and no battery no start.
Does your petcock have two lines running to it if it does it is vacuumed controlled. The reserve would be with the tab part of the petcock pointed forward the on is pointed down and it would freeflow and if pointed back it would be activated by the vacuum of the motor.
I don't know if this helps but it's my 2 cents!!
Look at your library for a manual mine had one !!
23 Mar 2010 08:26 #355606 by 650ed
Replied by 650ed on topic No start / Hard start
trianglelaguna wrote:
curious:
my new (to me) MK11 is not starting by the starter motor turing over....it did start when i was kicking it at the garage sale.....and i finaly ,felt,thought,it was not flowing fresh fuel into the carbs...kinda like sandy said...so i ran down the street and bump started it...got the gas station added fresh high oct...and still no starter button firing up...bumped it rode it home...took it out to fiddle with yesterday and chrged bat...but would only bump start...
Sounds to me like the starter is drawing so much current that there's not enough left to fire the plugs. If it was a fuel or carb problem I wouldn't think you could bump start it. I'd check the ground in the starter circuit and the starter itself to see if it's drawing more current than normal. Ed
