Drilling jets bigger?
- otakar
14 Mar 2010 20:02 - 14 Mar 2010 20:03 #353502
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Drilling jets bigger?
I'm Done Why dose it seam that this subject is covered about once a month to six weeks?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 14 Mar 2010 20:03 by otakar.
- bountyhunter
- Thank you received: 337
14 Mar 2010 21:53 #353546
by bountyhunter
Replied by bountyhunter on topic Drilling jets bigger?
otakar wrote:
He will probably have to spend $50 on a numbered drill set to get the sizes needed to do jets.loudhvx wrote:
Z1 sells the Dynojet kit. It's expensive, but you pay for the research. It includes 4 adjustable needles for easier tuning.
www.z1enterprises.com/detail.aspx?ID=4038
If this guy wants to drill jets, he dose not want to spend the $8 on the four jets. How do you expect him to spend $100 on a Dynojet kit. :ohmy:
- TeK9iNe
- What did you do!?!
- Thank you received: 28
15 Mar 2010 08:24 #353589
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Drilling jets bigger?
NOOOOOOOOOOOOOOOOOOOO!!!!
NOOOOOOOOO
NOOO
NOOO
NO
:laugh: :laugh: :laugh: :laugh:
Best of Luck!
NOOOOOOOOO
NOOO
NOOO
NO
Best of Luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- dysfunction09
24 Mar 2010 19:19 #355952
by dysfunction09
Replied by dysfunction09 on topic Drilling jets bigger?
Hey Polkat, I've put pod filters and Uni filters on bikes, and I generally jump up two sizes on the main jet and will usually jump up one size on the main jets. I know people will probably say I am doing things wrong, but I am from the "Make it work Academy" also known as RedNeck101. But I have had good luck going to god motorcycle shops and just exchanging jets, it did help that my friend ran the shop, but if you have a local shop you might check to see if the will pull a quick switcheroo for you. But generally jump up two sizes.
- polkat
- Thank you received: 1
24 Mar 2010 19:38 #355954
by polkat
Replied by polkat on topic Drilling jets bigger?
Just need to make sure I understand this based on what you wrote. You said you jump up two sizes on the main jet....and then one size on the main jet!? Do you mean the primary and secondary jets? And you have this done at God motorcycle shops? (I'm guessing you mean good instead of god).
Anyway, most people have advised me to up my jets from 125's to 135's and tune the piolet screw a bit. That's what I'm gonna try.
- JR
- Thank you received: 449
25 Mar 2010 19:06 #356187
by JR
Replied by JR on topic Drilling jets bigger?
www.z1enterprises.com/SearchResult.aspx?...True&KeyWords=keihin
Keihin jets 105 - 150. They also stock the smaller primary mains but you have to contact the guys at Z1
- zed1015
- Thank you received: 1581
26 Mar 2010 12:39 - 26 Mar 2010 16:32 #356331
by zed1015
Replied by zed1015 on topic Drilling jets bigger?
Most jets, mikuni etc are measured by flow rate but the keihin jets in my pumper carb are numbered by the hole diameter. i.e. a 100 main jet is 1mm dia, 120 = 1.2mm , 150 = 1.5mm etc etc. I bought a set of incremental drills off ebay for £8 ($15 ish ?) for just this purpose. There's 50 drill bits from 1mm to 6mm in increases of 0.1 mm Bargain.
Last edit: 26 Mar 2010 16:32 by zed1015.
