- Thank you received: 1
Drilling jets bigger?
- polkat
Okay, but this begs the question: What drill sizes equal what number (size) jets? Is there a listing somewhere showing jet numbers and the actual size of the holes?
Thanks!
- loudhvx
- Thank you received: 1616
en.wikipedia.org/wiki/Drill_and_tap_size_chart
You can probably just order jets for those carbs.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Joe Fabulous
2004 Harley Davidson Softail
1981 Z1000 Chop
1982 KZ1100 A2
XS 650 Plunger Chop (in bits)
- polkat
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- keith1
- Thank you received: 2
dont let OMR hear ya say that.....:laugh:
- polkat
The bike is a 1982 KZ750H3 four. It is bone stock, although I am doing a few bobber mods. I want to go to pods as I want the space that the airbox uses for something else, and because frankly, I like the pod look. I will also drill the stock mufflers with 6-1/2" holes around the main outlets. That is all the mods the engine will receive.
I've drilled lots of auto carb jets without problems and have lots of drill sizes. I figure why bother to go through the hassel of ordering jets when I can easily open up what I have. I just don't know what size to open them up to.
What would be a good ballpark pilot/main jet size for this (or leave the pilots alone as mentioned?)?
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- loudhvx
www.z1enterprises.com/detail.aspx?ID=4038
1981 KZ550 D1 gpz.
Other links.
- otakar
110 is stock? Okay, does anyone know the actual diameter of 110 jets?
They are not measured in size. They are measured in flow rate. size 100 = 100cc/min. That is on the Mikunis. Iam not kidding when I say that no one knows how the Kaihins are numbered. It is not just the size of the hole because three or four sizes might have the same hole but the length of the hole is different and the taper on each side is different. That is how the jets are fine tuned. On the average the difference between sizes is approximately .001" To give you a perspective, a #58 (.042") bit would be a 110 jet but the length of the hole now is the other variable, and that is if you ignore the tapers at each end.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Z1 sells the Dynojet kit. It's expensive, but you pay for the research. It includes 4 adjustable needles for easier tuning.
If this guy wants to drill jets, he dose not want to spend the $8 on the four jets. How do you expect him to spend $100 on a Dynojet kit. :ohmy:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- keith1
knowing this, it escapes me how someone can do a bike build and try to cheese out at every corner....no offense,
but ya got to cut loose with some cash if you are going to be successfull....if the cash isnt there, wait till it is.....
