- Thank you received: 2098
1978 kz650 sr 1980 moter and carbs
I have a tester that i put inbetween the wire and plug to check for spark if thats what u mean
The tester likely indicates when the spark plug is receiving at least "some" electrical current at "some" time.
Imo, a better test for spark existence and quality is visual inspection with the plug removed and held against engine head while spinning over the engine with electric starter and ignition switch turned ON. Look for fat blue spark.
This of course doesn't assure a correctly timed spark. Imo, dynamic timing with a strobe type timing light is more accurate than static timing with an ohmmeter or light bulb.
Should be able to see the advancer quickly move back and forth as rpm is varied by blipping the throttle.
Good Luck!
- sr man
- Hawk
Untill the sun dont shine
1978 kz650sr with 1980 E Ltd moter and carbs
Dyna Electronic Ignition
Dyna 3 Ohm Coils
Dyna wires
Progressive Springs Front Springs and
- and Rear Springs/Shocks
Wichita Kansas
- sr man
- Hawk
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- sr man
- Hawk
I completly went threw the carbs full dissemble and replaced all parts that u can even acc pump. When I set the vacc with my gages I couldnt get them 18 22 so I set them at about 10 so they would all be the same is that odd
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
- anarki650
- Thank you received: 5
16-40 sprockets
Isn't stock gearing 16-42? Missing two teeth on the rear sprocket would account for some of the low end power loss.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- sr man
- Hawk
KZ650-D1/D1A 590010-001
This is from bike bandit
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
- Bluemeanie
- Thank you received: 14
- sr man
- Hawk
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
Good Luck!
- Bluemeanie
The 16 inch rear wheel is why
Oh right, forgot about that!
- sr man
- Hawk
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
