1978 kz650 sr 1980 moter and carbs
- sr man
- Hawk
new pistons and rings 177 lbs compression
Untill the sun dont shine
1978 kz650sr with 1980 E Ltd moter and carbs
Dyna Electronic Ignition
Dyna 3 Ohm Coils
Dyna wires
Progressive Springs Front Springs and
- and Rear Springs/Shocks
Wichita Kansas
- PLUMMEN
- Thank you received: 104
- sr man
- Hawk
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
- sr man
- Hawk
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
- PLUMMEN
- Thank you received: 2098
does all the kz650s have a lack of low end power
Is it for certain that the engine has combustion in all four cylinders?
Has water mist been sprayed on exhaust header pipes after first starting cold engine and allowing about 15 seconds to heat the headers? Spray should immediately vaporize and sizzle off all four headers. Water running down a header indicates failure of combustion inside the cylinder.
Good Luck!
- sr man
- Hawk
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
- sr man
- Hawk
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
- sr man
- Hawk
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
- sr man
- Hawk
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
It has less then 700 miles on a freshly rebult moter new pis new rings new valves new dana no points pulls hard at 4000 on up horrible off the line
pulls hard at 4000 on up horrible off the line --- am thinking this indicates the bike is performing with less than normal low end power.
If not already done, would assure automatic advancer unit isn't stuck in forward position.
Possibly a carb issue at lower rpm, such as sync, or pilot adjustment, or pilot circuit.
But would first rule out any non-carb problems.
Good Luck!
- roy-b-boy-b
- Thank you received: 103
