Do pods create excessive oil pressure??
- chrispysaki
I thought the fact that there was oil rather than air coming from the breather might have been a sign of too much pressure. I took the breather filter off on the way home last night and it didn't seem to leak as bad, but then again, I didn't rev it past 5-6k at all.
- PLUMMEN
- Thank you received: 104
- Old Man Rock
- Thank you received: 225
Where the hell have you been hiding this sweet KZ... Love it!
As for the oil breather line... Longer lines down and to the left side facing the ground behind and outside of the rear set... Plummen taught me that trick. Originally had a filter on it...
During hard runs, I would get this squishing noise... Drove me crazy, no one could figure it out in the AVI clips... Out with the stethoscope.... Traced it down (loudest) area between oil pump, clutch components... Replaced both... Quieted it down but still present at times... Had a slipping clutch anyways so that was left on the to do list just the same.
Removed breather filter, new longer breather line, haven't heard the noise since... Gee, go figure! :S :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- loudhvx
- Thank you received: 1616
Don't let the hose get pinched or kink.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- PLUMMEN
carefull with that classified info,remember im not supposed to know anything! :laugh:Well looky-looky!
OMR
- thompsonmx100
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
- chrispysaki
- larrycavan
- Visitor
There's more info on the crankcase breather in this thread than Kawasaki put in all their manuals combined :laugh:
Plummen is correct! You're a tad on the high side with oil level.
- rstnick
- Thank you received: 377
The KZ that is.
I ran a tube all the way back to the tail light for the vent.
Didn't work too well because any low spots trapped moisture which collected and formed a puddle. Had I left it long enough, it would have blocked off the air flow.
Make sure any hose you use doesn't have a low spot like a letter U.
Just up and over where the airbox used to be, then down.
Some use a can to collect the oil.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- Thank you received: 2098
Good Luck!
[Click on image to enlarge view]
