Do pods create excessive oil pressure??
- chrispysaki
It also started leaking oil from the front of the motor again pretty bad on the way in to work today. I installed new head and valve cover gaskets less than 100 miles ago, as well as valve stem seals, to address the oil leak when I first installed the pods.
Last night I attached a piece of a towel to the vacuum air intake (that goes to the exhaust side of the valve cover) to reduce the air flow since that also used to connect to the air box. I don't know if that has anything to do with the increased oil leak today?
I'm probably going to replace the lower head/crankcase gasket in hopes that it solves the oil leak, but I'm worried that the pods are somehow creating too much oil pressure throughout the motor/transmission/etc.
Oh and here are a couple quick pics of the bike...oil spots included!
- chrispysaki
- chrispysaki
- chrispysaki
- rustedcutlery
also, do you know what your crankcase pressure is? and how fast are you spinning the motor? does it seep/leak all of the time or just under load?
- keith1
- Thank you received: 2
When I installed the pod filters on my carbs (1980 kz750 E1), I put another pod style filter on the breather case, which also used to connect to the airbox. I just noticed that the breather filter is completely saturated in oil.
oil on breather normal..amount depends on internal condition of motor
try re-torqueing head gasket
try re-cinching valve cover bolts
- PLUMMEN
- Thank you received: 104
- JR
- Thank you received: 449
Luckily we never had that anti smog stuff up here with hoses running in and out of the valve covers and to and from the airbox. I hear a lot of people say they got rid of that stuff but even so I would doubt that would cause your problems with leaking oil.
Like keith1 says ....did you try re torquing the head bolts and valve cover ?
- chrispysaki
- Thank you received: 2829
- JR
I'll try re-torquing everything tonight, but you brought up something I was wondering about those clean air vacuum intakes-whether they're needed, and whether it would improve performance if I capped them. The way I think it was explained in the manual is that the air is sucked into the cylinder when a negative pressure situation is created during the exhaust cycle.
I have heard that people just run a hose or tube from one side of the valve cover to the other and then block off or remove the stuff to the airbox. But like I said we never had it up in Canada so I'd suggest doing a search here or wait for someone who knows to come along.
- hoghaterkaw
