- Thank you received: 2
29 MM smoothbore question
- keith1
20/120 9 air and the sudco mikuni manual says the standard
jetting they sold them with for a kz1000 is 25/120 9 air....
any input?.....if i read the sudco book right, the pilot mixture screws are on the side.....should be a lot easier to tinker with than the other vm series on the bottom....
- trianglelaguna
- Thank you received: 235
.anyway..i know you know all this stuff but that is my input...you'll dig em.....mine were jetted for a 1000 somthing hot rod motor the p.o said...i cleaned em and threw em on my 903 cc tired motor with some filter pods and a supertrapp...and the difference was pretty decent.. .. by now i can see where they lag a bit...while the pistons seem to catch up to speed with the flow of fuel...........jetting?...i just ride it...oh well....shows how much i know....:woohoo:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- keith1
- saxjonz
- KawboyZ
- Thank you received: 76
It just depends on the setup.
79 LTD B3
- saxjonz
- KawboyZ
This is as much as I know about the jetting. It will make a difference with different setups and engine condition.
79 LTD B3
- keith1
If the setup is for what you have listed then maybe the pilot jet could be good 20-25 but the main you will find that 125 should be good has to be bigger than 120. I am running lean with my setup but I am going to put different carbs on over the winter so I will just ride a few hundred more miles. That part makes a good difference when the carbs are tuned and jetted correctly for the setup. The carbs will need to be synced etc.
sax,
thanks for the input...these carbs should be here mon/tues
and i will give them the once over when they get here...i think my andrews 2x(mild street cam) might be the diff on the main.....360 vs 410....but then again....i have a suspicion that i will have to bump up main to 125....i guess a little carb install/re-install will be coming up.....thanks again....
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- keith1
- keith1
it s gonna need 25 pilots...revs hang up pretty bad and i tried a 1/2 turn out on the pilot screws...not much of an improvement....took a quick blast down the street and pulled pretty good considering....these should be sweet dialed in......
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- saxjonz
- KawboyZ
PS Were you talkin bout Dave? And his CR's? Have you tried em?
keith1 wrote:
installed them with new boots and she fired right up...worked great on choke....
79 LTD B3
- saxjonz
- KawboyZ
Get them dialed in and they should make a big difference. I have a set wth butched pilots that I miss. Talk about a letdown going from the smoothbores to the regular 28's. I'm jealous now, anyone have parts for the smoothies send me a PM.
79 LTD B3
