- Thank you received: 2098
#4 Plug Fouling
07 Jun 2009 16:12 - 10 Jun 2009 17:36 #297082
by Patton
Replied by Patton on topic #4 Plug Fouling
My added text covered some of the original text which is shown in the following post.
Good Luck!
[Click on image to enhance view]
Good Luck!
Last edit: 10 Jun 2009 17:36 by Patton.
07 Jun 2009 16:14 - 07 Jun 2009 16:18 #297083
by Patton
Last edit: 07 Jun 2009 16:18 by Patton.
- 88alltrac
07 Jun 2009 17:21 #297099
by 88alltrac
81 KZ1000 K1
Lincoln NE
Replied by 88alltrac on topic #4 Plug Fouling
those drawings are great. a little to late but great none the less. i found some o rings today that fit perfect on those plugs. i have it all back together but havent thoroughly tested it yet.
81 KZ1000 K1
Lincoln NE
- 88alltrac
10 Jun 2009 15:11 #298070
by 88alltrac
81 KZ1000 K1
Lincoln NE
replaced the orings and threw in some new plugs and still doesnt work.
i am very frustrated with it and wish i could just take it in but i am very poor at the moment.
sometimes after i drive it the #4 pipes is hot like the rest. other times it is just warm. in this way it seems to be intermittent.
but no matter if the pipe was hot or cold it has a buzziness to it at around 3500-4000 rpms and up which i think is from the misfiring cylinder
81 KZ1000 K1
Lincoln NE
- 88alltrac
16 Jun 2009 14:41 #299684
by 88alltrac
81 KZ1000 K1
Lincoln NE
i have the carbs at a mechanic right now. he says the k&l float needles and seats that i just put in are not good. there is also a tiny amount of rust in my tank.
the OEM float valves are spendy $$$ but he seems to think that is the problem. i just dont understand why i am only having a problem with 1 cylinder. it is never one of the other 3. i didnt realize these carbs where so touchy and difficult to get running right.
and i guess my inline fuel filter must be junk because it doesnt filter out the rust.
i dont think i can afford to fix my carbs. that is a bummer.
81 KZ1000 K1
Lincoln NE
16 Jun 2009 16:18 #299701
by Patton
To rule out possible petcock diaphram fuel leakage issue (whereby fuel might be sucked into carb vacuum nipple through the tube connecting carb vacuum nipple to petcock vacuum nipple), could cap/plug the carb vacuum nipple that usually furnishes vacuum to the petcock. Thereby eliminating any possiblity of unwanted fuel entering the carb vacuum nipple.
Install a brand new spark plug in #4 cylinder. And test run with petcock in PRI position (so petcock will flow fuel without any vacuum being supplied to petcock).
The brand new spark plug is recommended because a relatively new plug that's been fuel fouled may appear perfectly okay, and maybe even fire outside the cylinder, but never-the-less be beyond hope of recovery. I don't know why NGK plugs seem to suffer such affliction, but it happens.
After test running, be sure to turn the petcock to RUN or RES position, and not leave it in PRI position.
Good Luck!
Good Luck!
- 88alltrac
16 Jun 2009 18:17 #299731
by 88alltrac
81 KZ1000 K1
Lincoln NE
my #2 carb is connected to the petcock so that isnt the problem.
the bike sure runs strong and has lots of power. i wouldnt hardly know that it wasnt firing on 4 except for a vibration that i get above 4-5k rpms and the pipe being only lukewarm.
i expected it to be sluggish and slow but it sure moves. i cant imagine what it will be like on 4 cylinders.
81 KZ1000 K1
Lincoln NE
- 88alltrac
16 Jun 2009 18:30 #299734
by 88alltrac
81 KZ1000 K1
Lincoln NE
the only part in the carb that i hadnt switched from one to the other was the needle jet or emulsion tube or whatever it is called. today i swapped them over. no change in scene.
i am getting the matches out.
81 KZ1000 K1
Lincoln NE
- OKC_Kent
16 Jun 2009 18:43 #299741
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic #4 Plug Fouling
88alltrac wrote:
Stick with it. Use the matches to light your Victory cigar.
Oklahoma City, OK
- 88alltrac
16 Jun 2009 18:59 #299751
by 88alltrac
81 KZ1000 K1
Lincoln NE
i am quite short on money but i am thinking of buying another set of carbs. i am really out of any other ideas.
81 KZ1000 K1
Lincoln NE
