#4 Plug Fouling
- 88alltrac
81 KZ1000 K1
Lincoln NE
- Thank you received: 2829
- Thank you received: 2098
my bs34's dont have float bowl vents. i dont really know where they are supposed to vent to. they also dont have the rounded bottom on the slides like those. it is just flat across the bottom.
Click here > Vents R Us
Good Luck!
- 88alltrac
the bowls just vent directly into the airbox.
81 KZ1000 K1
Lincoln NE
Where so fitted, such jet should be in perfect as new condition, unclogged and undamaged. Otherwise, insufficient air is allowed into the pilot circuit which results in an excessively rich fuel mixture in the pilot circuit.
Good Luck!
- 88alltrac
i just put a new petcock rebuild kit in my vacuum petcock and new float valves and seats. i still have the problem where when it is parked gas will overflow out of the carbs. any ideas here. i have a fuel filter so it shouldnt be crap getting stuck in there.
also the plug that go over my pilot jet dont fit snugly. they are fairly loose in there. is this going to be a problem? they are loose in all 4 carbs but i am only having trouble with 1. i cant find replacements for these. maybe i could find some orings at a hardware store.
81 KZ1000 K1
Lincoln NE
- dkmk
- Thank you received: 18
All four carbs, or just #4? Did you examine your floats closely (bent/nicked guide pin(s))still have the problem where when it is parked gas will overflow out of the carbs
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
- 88alltrac
81 KZ1000 K1
Lincoln NE
mine doesnt have the slot in it so i am not sure that it is removable....
Any slot in other three carbs?
Perhaps the slots have been twisted away. :pinch:
Good Luck!
- 88alltrac
81 KZ1000 K1
Lincoln NE
- 88alltrac
i am going to try to find some orings i can put in there. buying them new from kawasaki is expensive.
81 KZ1000 K1
Lincoln NE
i dont know which carb is leaking. they are brand new float needles and the pins all appeared to be straight and move freely.
Could determine which carb by placing a separate catch jar at each overflow tube exit underneath the bike.
Or detach tubes from overflow nipples and watch for escaping fuel.
Good Luck!
