deceleration after freeway speeds
- jzanutto
is that correct with the rest of you guys?
1978 KZ650B 2004 BMW R1150RT
- keith1
- Thank you received: 2
jzanutto wrote:
one question for the record, are these the stock carbs for a 78KZ650B??
With the air screw on the side, I'd say no, that they're not correct. Does the number 2 carb have the accelerator pump on it (you'll know it as it's much different than the other three)?
quick question...emgo pods? do they not need any oil?..i was under the impression all pods no matter the type needed oil to catch contaminants...????
- jzanutto
- Thank you received: 2829
Yes, they are the correct carbs. Ed
- N0NB
- Blue handles better
i could be wrong, but the extra ribbing going horizontally on carb bodies is from an older style...???
All of the pictures and the 650s I've seen with Mikuni carbs, the carb bodies have the horizontal ribs.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- jzanutto
- Thank you received: 2098
Thinking grit and crud inside tank suspended in fuel and hovering around and collecting on petcock pick-up screens.
Good Luck!
- jzanutto
If it was starvation I would think it would cut out while going 70 down the freeway, but it runs fine and has great power.
for now, 2 things I am trying - 1. is the "stuck advancer" theory (its all cleaned up and lubed) and 2. too lean on the pilot circuit. ( I will close my pilot air screws about 1/2 turn and see if it helps)
- jzanutto
