deceleration after freeway speeds
21 Apr 2009 15:46 - 21 Apr 2009 15:49 #283759 by jzanutto
deceleration after freeway speeds was created by jzanutto
my 78 KZ650 B has stock carbs, pods and kerker. I have it all pretty much dialed in now, it runs great but today I took it to work to show off and after riding about 10 minutes of sustained freeway speed (70), once I came to a stop at the stoplight it wanted to idle real low and died.
Once I started it back up and headed onto work on the regular roads it was just fine. Then on the way back from work, it was just the same. Ran fine on the surface roads, then 10 mins of freeway and pulled the clutch in while on the offramp and it wanted to die so I babied it with the throttle while sitting at the light. Then it cleared up and ran normal.
Anyone had this? or know what it might be?
this is a total rebuild bike - new carb boots, sealant on the boot - to - head joint, carbs overhauled, jets are stock, timing is set, etc, etc. please dont even mention the coil wire relay thingy..... sheesh thats the fix for everything these days! I have a new wire harness, handlebar controls and plugs, wires...
It is completely normal except for this.
1978 KZ650B 2004 BMW R1150RT
Last edit: 21 Apr 2009 15:49 by jzanutto.
21 Apr 2009 15:51 #283761 by PLUMMEN
Replied by PLUMMEN on topic deceleration after freeway speeds
have you run a compression test on it once it warms up? :(
21 Apr 2009 16:11 #283773 by N0NB
Replied by N0NB on topic deceleration after freeway speeds
Besides a compression test, are you sure the vent passage in the fuel cap is clean? When I redid my tanks I made sure the vent was clean with a generous dose of carb cleaner.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
21 Apr 2009 16:15 #283775 by jzanutto
Replied by jzanutto on topic deceleration after freeway speeds
one question for the record, are these the stock carbs for a 78KZ650B??
21 Apr 2009 16:16 #283776 by jzanutto
heres how they look
21 Apr 2009 16:20 - 21 Apr 2009 16:26 #283779 by loudhvx
Replied by loudhvx on topic deceleration after freeway speeds
That is the classic symptom of needing to do valve shims.
The valves heat up on the expressway just enough to not seal, but you can't notice the difference on the highway. At idle the leakage is just enough to kill the motor. After just a few minutes the valves shrink just enough to seal again and all seems fine.
The problem will be worse on hot days, and maybe not noticeable on cold days.
A valve-lash check is in order.
Also should mention, a compression test will not reveal any problem. The engine cools so fast that the valves seal back up in moments. By the time you do the comp test, everything is back to normal.
Only checking the lash will tell the story.
Last edit: 21 Apr 2009 16:26 by loudhvx.
21 Apr 2009 16:25 #283781 by N0NB
With the air screw on the side, I'd say no, that they're not correct. Does the number 2 carb have the accelerator pump on it (you'll know it as it's much different than the other three)?
Nate
21 Apr 2009 16:28 #283785 by loudhvx
I believe there was more than one type of carb for the 77 and/or 78 650's. At least I've seem to come across more than one type. It makes air/mixture screw and jetting info confusing.
They look similar, though.
21 Apr 2009 16:35 #283789 by keith1
Replied by keith1 on topic deceleration after freeway speeds
i could be wrong, but the extra ribbing going horizontally on carb bodies is from an older style...???
21 Apr 2009 16:43 - 21 Apr 2009 16:44 #283791 by jzanutto
every one of the valves are between .003" and .004". Just went through the engine. No accelerator pump
Last edit: 21 Apr 2009 16:44 by jzanutto.
21 Apr 2009 16:47 #283795 by cmmman
Replied by cmmman on topic deceleration after freeway speeds
If you have pods and the kerker you may want to adjust the jetting.
1977 KZ650B, modified.
21 Apr 2009 17:02 #283812 by jzanutto
I will also see if my advancer is hanging open.
