deceleration after freeway speeds
- jzanutto
Once I started it back up and headed onto work on the regular roads it was just fine. Then on the way back from work, it was just the same. Ran fine on the surface roads, then 10 mins of freeway and pulled the clutch in while on the offramp and it wanted to die so I babied it with the throttle while sitting at the light. Then it cleared up and ran normal.
Anyone had this? or know what it might be?
this is a total rebuild bike - new carb boots, sealant on the boot - to - head joint, carbs overhauled, jets are stock, timing is set, etc, etc. please dont even mention the coil wire relay thingy..... sheesh thats the fix for everything these days! I have a new wire harness, handlebar controls and plugs, wires...
It is completely normal except for this.
1978 KZ650B 2004 BMW R1150RT
- PLUMMEN
- Thank you received: 104
- N0NB
- Blue handles better
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
- jzanutto
- jzanutto
- loudhvx
- Thank you received: 1616
The valves heat up on the expressway just enough to not seal, but you can't notice the difference on the highway. At idle the leakage is just enough to kill the motor. After just a few minutes the valves shrink just enough to seal again and all seems fine.
The problem will be worse on hot days, and maybe not noticeable on cold days.
A valve-lash check is in order.
Also should mention, a compression test will not reveal any problem. The engine cools so fast that the valves seal back up in moments. By the time you do the comp test, everything is back to normal.
Only checking the lash will tell the story.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- N0NB
one question for the record, are these the stock carbs for a 78KZ650B??
With the air screw on the side, I'd say no, that they're not correct. Does the number 2 carb have the accelerator pump on it (you'll know it as it's much different than the other three)?
Nate
- loudhvx
They look similar, though.
1981 KZ550 D1 gpz.
Other links.
- keith1
- Thank you received: 2
- jzanutto
- cmmman
1977 KZ650B, modified.
- jzanutto
