Praise for Wired George
- Pro_window78
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- loudhvx
- Thank you received: 1616
voltage was checked before and after mod with engine not running - and improvement in voltage noted as in previous post - no load on anything - therefore sdditional load taken by Dyna S - is irrelevant as its only there when running.
Not true. The Dyna S uses full current to the coils whether the engine is running or not as long as the ignition is turned on.
As I said, with the Dyna S, the relay mod will definitely show an improvement since the Dyna S uses almost twice the average current as the stock points setup, and even more if the coils are 3 ohm.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- GalwayZ
No point in debating this any further - as i said my intention was to point out its a good mod - you obviously have an issue with either the mod itself or its origin - either way it worked well for me - if it helps others then all the better -
end of-
- loudhvx
With the Dyna S, you could probably just hard wire the coils to the battery since the Dyna will shut them off when the igition is off. Same is true with the Kaw elec.ign. You really only need the mod with points.
1981 KZ550 D1 gpz.
Other links.
- jzanutto
i still havn't done the coil mod do you think my kz1000r would benefit?
or is it for the older zed's.
Kano, disconnect your hot wire from your battery, then unplug your coils from the yellow/red wire. Set the switches to ON and RUN and then connect an ohmmeter to the hot terminal, and to the coil terminal.
If the resistance reads zero, or near zero then the coil mod will do nothing for you. It eliminates resistance in the circuit to the coils by installing new wires.
1978 KZ650B 2004 BMW R1150RT
- loudhvx
The most common culprits are the kill switch, fuse holders, ignition switch, connectors, then the wires themselves, probably in that order.
1981 KZ550 D1 gpz.
Other links.
- Pro_window78
- loudhvx
As I said, I've recommended WG's mod before and I'm sure I will again.
This is the only degree I use every day.
1981 KZ550 D1 gpz.
Other links.
- Mcdroid
- Gone Kwackers
- Thank you received: 318
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- JMKZHI
- Thank you received: 48
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
