Praise for Wired George
- GalwayZ
31 Mar 2009 15:15 #277081
by GalwayZ
Praise for Wired George was created by GalwayZ
Just a quick note to say - wired georges coil rewiring tip - should be mandatory in order to get membership on the site, instant improvement in idle, clean plugs - smooth running and more power - and all for little or no investment and about 2 hours work.should be the starting point for all!
- kano
- Not Another Bloody Limey!
31 Mar 2009 15:19 #277082
by kano
Replied by kano on topic Praise for Wired George
i still havn't done the coil mod do you think my kz1000r would benefit?
or is it for the older zed's.
- loudhvx
- Thank you received: 1616
31 Mar 2009 15:26 #277083
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Praise for Wired George
No benefit if you already have good voltage to the coils. prefer less contraptions in the electrical system. I just clean the switches and fix wiring problems.
The relay method is a good shortcut if you don't want to fix the wires, switches, etc.
So I guess I'd have to forfeit my membership, then.
1981 KZ550 D1 gpz.
Other links.
- GalwayZ
31 Mar 2009 15:27 #277085
by GalwayZ
Replied by GalwayZ on topic Praise for Wired George
All i can say is - it worked wonders for my 78 650. Checked the coil voltage (engine off) before mod - less than 10 volts ( battery is good) - Coil voltage after mod - 11.97.
Idle inmproved and plugs that were previously sooty - now nice light tan colour.Engine is smoother right through the range - i have dyna s ignition and dyna coils/wires - plugs were bad even on this set up untill i wired according to WG's plan.DIfferent Bike.!!!
- loudhvx
31 Mar 2009 15:32 #277092
by loudhvx
1981 KZ550 D1 gpz.
Other links.
The Dyna uses so much excess current, the relay will really make a difference on that setup. I prefer the factory electronic ignition since it uses far less current.
1981 KZ550 D1 gpz.
Other links.
- GalwayZ
31 Mar 2009 15:33 #277094
by GalwayZ
I went through the loom from end to end cleaned and tightened every connection - wiring is my stock and trade - 30 year old switchgear on the bars was the root of my issue and cleaning didnt improve.
each to his own !
each to his own !
- mtkawboy
31 Mar 2009 15:40 #277099
by mtkawboy
Replied by mtkawboy on topic Praise for Wired George
WG has been a huge help to me on the carbs on a lot of my other bikes too, not just Kawasakis along with the coil mod
- GalwayZ
31 Mar 2009 15:43 #277100
by GalwayZ
voltage was checked before and after mod with engine not running - and improvement in voltage noted as in previous post - no load on anything - therefore sdditional load taken by Dyna S - is irrelevant as its only there when running.
- trianglelaguna
- Thank you received: 235
31 Mar 2009 15:46 #277103
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Praise for Wired George
wait a second....first a bunch of folks talk bad about folks that help out .....and now you guys are saying people that help folks out are good.....
now which one is it gonna be...helping is good....or helping is bad....i am so confused
1976 KZ900
2003 ZX12R
2007 FZ1000
- GalwayZ
31 Mar 2009 15:53 #277106
by GalwayZ
All i wanted to point out was - this really worked for me and should be starting point for any one with an older bike - and also to give a little thanks for a genuinely usefull tip - if someone else thinks is pointless thats there opinion.
I havent used this forum much but have only found people on here to be extremely helpfull over all - in fact I've only gotten good advice/help and am gratefull for all of it.
I think i'll leave it there
- trianglelaguna
31 Mar 2009 16:03 #277113
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
no dude my joke is in 110% support of your thanking him....he helps tons of folks on here...i think that is a coil mod i gotta do too.....
sorry if i seemed to poke fun at your post....the exact other is what i meant...he is a cool dude....craig
1976 KZ900
2003 ZX12R
2007 FZ1000
- toadson
31 Mar 2009 16:10 #277115
by toadson
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
Replied by toadson on topic Praise for Wired George
My bike had 14v at the coils, but I decided to do the mod anyway. Of course there was no difference, but I figure the bike could only benefit in the long run. Even if this mod does fail for some reason, I have all the old wiring in tact, so this mod basically cost me nothing but time (already had the relay and wiring).
