CRAZY AIRFILTER IDEA
- soccerd31
30 Apr 2009 09:55 #286525
by soccerd31
1981 KZ750 LTD H2
Replied by soccerd31 on topic CRAZY AIRFILTER IDEA
balance is key... just like the two into one pictures that have been recently posted... as long as everything runs the same distance to the filter you will have balance... where as if you have the distance from 1 to filter be half that of 4 to the filter you won't have balance.... sooo if all of your pipes lead the same distance to the filter it would work... (my theory says it should balance and work) so like those two into ones that have been shown they have a short pipe (equidistant of eachother) leading to a longer pipe... but they have the same distance to the filter... if you want it to all run into one.. make sure your pipes have the same distance to the filter so it can balance and draw the same amount of air euqally to the carbs...
1981 KZ750 LTD H2
- soccerd31
30 Apr 2009 10:05 - 30 Apr 2009 10:06 #286526
by soccerd31
Last edit: 30 Apr 2009 10:06 by soccerd31.
- Thank you received: 797
30 Apr 2009 14:25 #286558
by 531blackbanshee
Replied by 531blackbanshee on topic CRAZY AIRFILTER IDEA
yes get those pics up wompy.delrin stacks,i love machining plastic:cheer: .
leon holmes
leon holmes
- wompy5000
30 Apr 2009 20:27 #286675
by wompy5000
jpriderdesigns.blogspot.com
Replied by wompy5000 on topic CRAZY AIRFILTER IDEA
Here they are kids. Enjoy the radness!!!!!!!!!
- wompy5000
- kano
- Not Another Bloody Limey!
30 Apr 2009 20:37 #286677
by kano
Replied by kano on topic CRAZY AIRFILTER IDEA
problem?
- wompy5000
30 Apr 2009 20:52 #286678
by wompy5000
- kano
30 Apr 2009 20:54 #286680
by kano
never seen those before k&n?
- wompy5000
- wompy5000
30 Apr 2009 21:44 #286731
by wompy5000
- toadson
- Thank you received: 1
01 May 2009 00:16 #286898
by toadson
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
Replied by toadson on topic CRAZY AIRFILTER IDEA
I like the design Wompy, but have you test fitted them on a bike yet? Just wondering if theres enough clearance or not.
- wompy5000
01 May 2009 15:40 #287016
by wompy5000
Carbs still out at wired-george being rebuilt. I measured the clearance b4 they went out and am pretty confident they will fit a stock bike even though I am hardtailing mine and those down tubes will probably be moved back some.
