- Thank you received: 391
Throttle shaft grommet 76 900
- Motor Head
20 Jan 2011 18:24 #423992
by Motor Head
Replied by Motor Head on topic Throttle shaft grommet 76 900
I wonder if the next Carb builder will be so lucky? Seems there hard to come by new. If anyone knows where to get new ones hopefully they will share.
- calvin17d
- Thank you received: 1
20 Jan 2011 22:18 #424041
by calvin17d
1976 Kz900 A4
Replied by calvin17d on topic Throttle shaft grommet 76 900
I found a 1 place that would sell them used for $6.00 ea. I found 1 on ebay for $29.00 and found place online that had three and another that had six new. They were listed between $6 & $7 dollars. I would be more than happy to pick some up from the vintage store if anyone is hard up. This guy had isles of mikuni's that he said I could rip apart. I wouldnt mind grabbing myself an extra set while im there. I might even start my own little grommet business:woohoo:
1976 Kz900 A4
- ed spangler
- Tennessee Z
- Thank you received: 29
21 Jan 2011 05:47 #424075
by ed spangler
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
Replied by ed spangler on topic Throttle shaft grommet 76 900
Try Redline
- KZJOE900
- Admin
07 Jul 2011 01:15 - 07 Jul 2011 11:02 #461465
by KZJOE900
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Replied by KZJOE900 on topic Throttle shaft grommet 76 900
I am having the same issues with these grommets. I have found a company
www.lakeviewindustries.com
, which manufactures but does not sell directly to the public, a grommet (item number 11495B600) which is pretty close in dimensions. Here are the specs:
Inner dia. 1/2 in (Note: I took my shaft to ACE hardware and tried a grommet with a 1/2 in dia. Fit nicely. But that was the only dimension which matched. But this told me that 1/2 inch works.)
grove dia. 13/16 in.
outer dia. 1 and 1/16 in. A bit larger put who cares since it won't effect function part of the fit.
Looking from the side of the grommet.
grove width 3/16 in.
overall thickness 7/16 in. Once again this measurement is not a factor in the fit.
I have ordered through a local vendor (national chain) called fastenal. Should be getting them in a couple of days to try. Cost me about $10 bucks for 6 of them since he had to have them shipped from another fastenal store. Will let you know how it works out.
Cheers!
Cheers!
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 07 Jul 2011 11:02 by KZJOE900.
- calvin17d
07 Jul 2011 01:45 #461470
by calvin17d
1976 Kz900 A4
I spent about a month trying to track these down. After many calls to bike clubs, vendors, Overseas, I finally found them at a local cycle salvage. Turns out the mikuni carbs were quite popular in the last 40 years. I walked out with all six and a few spares for 5 bucks.
Be cautioned the oem rubber has a thin diaphragm that creates a seal around the rod.
1976 Kz900 A4
- KZJOE900
- Admin
07 Jul 2011 10:57 - 07 Jul 2011 11:05 #461505
by KZJOE900
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Yes, Calvin. I have noticed the thin membrane like diaphragm on mine as well. I felt I had no other choice but to try these ones I ordered. Not sure if it is going to work. If it works, it should idle steady and have a steady rpm when driving at a constant speed. If they leak, I think the rpm's will fluctuate. Or at the least it will run lean. If unsuccessful, maybe I can get some contact information from the place you got yours. I have new brass fuel tee's coming as well. I should have it resembled by this weekend. I know the bike is good electrically since I was able to spray starting fluid in each carb (prior to the rebuild) and it would roar to life for a couple of seconds. I will post the results once I have some results.
Cheers!
P.S. How is your bike running now? Did the new grommets do the trick?
Cheers!
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 07 Jul 2011 11:05 by KZJOE900.
- Kidkawie
- I bleed premix
- Thank you received: 245
07 Jul 2011 11:52 #461508
by Kidkawie
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Replied by Kidkawie on topic Throttle shaft grommet 76 900
Has anyone emailed Sudco?
1975 Z1 900
2004 KX125
