Z1 fuel cock
- eaglecrash2
14 Jan 2009 18:42 #257937
by eaglecrash2
'77 kz650,'06 Vulcan 500ltd, '07 ducati 1098s, '03 bmw m3, '85 carrera, '71 911s, '06 s2000, '03 suburban, '76 triumph TR6
sold: '69 honda 250, yr(?) 50cc honda moped, '52 Beechcraft Bonanza
Long Beach, California
Replied by eaglecrash2 on topic Z1 fuel cock
Yes there is something wrong. It's brand new and all I did was enlarged the hole in the fuel tank and then mount it. The petcock has not been taken apart at all. I tried different lever positions but you are right I'll pull the fuel line when I get a chance and observe what it does in the different positions.
- Thank you received: 2098
14 Jan 2009 20:15 #257950
by Patton
Replied by Patton on topic Z1 fuel cock
If not already done, would assure that the Off and Reserve positions are not being mixed up by mistake. Thinking the petcock may be left in Reserve when thought to be Off while parked overnight..
Good Luck!
Good Luck!
- Iron Duke
- what are you rebelling against?
14 Jan 2009 21:42 #257967
by Iron Duke
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
Replied by Iron Duke on topic Z1 fuel cock
Iron Duke wrote:
Looking at the Budget Xs650 Universal Petcock & adapter (as seen on 650motorcycles.com) but need source?? part/brand # are Tucker/Rocky,and/or Bikers Choice #49-600, and adapter is made by pingel # 181671I have a 82,550 with vac petcock, is it 44mm, will t
he fit be same as on 650?
1982 KZ550 LTD C-3
- eaglecrash2
15 Jan 2009 19:14 #258150
by eaglecrash2
Patton wrote:
It's not mixed up at all. I pulled the line and observed the results of the 3 different positions and it worked as marked except in the off position it keeps dripping. With closer inspection I noticed a small black piece of debris in the fuel line entering the in-line filter. With suspicion I drained the tank and took the pingel petcock apart and lo and behold the rubber seal has a piece missing. It was torn and that's the piece in the fuel line. That explained why it's dripping in the off position as it wasn't sealing properly. I'll call Z1 enterprise in the morning.
Good Luck!
- jzanutto
15 Jan 2009 20:02 #258157
by jzanutto
1978 KZ650B 2004 BMW R1150RT
Replied by jzanutto on topic Z1 fuel cock
good find... I bought one of the Z1 petcocks for my H2 last year and it works perfectly. WHen its off, its OFF. no leaking or dripping. I hate my garage smelling like gas
- eaglecrash2
16 Jan 2009 13:18 #258280
by eaglecrash2
You're lucky. I talked to a Z1 rep this morning and he said there is a batch of the petcock with the seal not seated properly. Nevertheless he's rushing me a new seal. Bad thing is i smell gas in the oil so now i have to change out the oil and filter.
